Cube extruding a long a path as a loop
Bembelrocker
Post by Bembelrocker » Mon May 21, 2012 7:38 pm
I tried it several times, but i'am not able to stretch a cube along a path which will form a loop.
How can i do that ? Is there a good tutorial out there ? I know how to extrude, but not along a path or bezier curve.
:cry:
RoboticGolem
Post by RoboticGolem » Fri May 25, 2012 8:02 am
I've done something like this. (If its what I'm thinking you mean)
Make your mesh, then your path.
select your mesh, add a generate array modifier, and tell it to fit your path.
Then add a curve deform modifier with your path again, and viola!
