Problem with stubborn edges
KiriHime
Post by KiriHime » Sun Aug 19, 2012 5:44 pm
Mmkay. I'm new to this and I've kind of been figuring it out as I go along. I did run into a problem though. I tried moving an object [with a black material assigned] but an extra black patch stayed behind. I deleted said object to see what would happen, and still the black remained. I went into the wireframe and discovered that there is the outline of the object there made up of only edges without vertices. I can't seem to even select them. What can I do?
Also, I have another question. I noticed as I was going in and out of object mode that it doesn't appear as it does in edit mode. Like an object with a straight edge will have some dips in it. I checked all around the object and there's no reason for it to have those dips, so I was just wondering why this was.
ldo
Post by ldo » Wed Aug 22, 2012 12:46 pm
In your Outliner window (upper right of the default workspace layout) you should see a list of the objects in your document. You can click on each one to select it there.
