Snap to surface
clem
Snap to surface
Post by clem »
hik i am a landscape planner and I want to use blender for visualisation of a landscape. I use Arcview for the analysis and layout of maps.
I have a landsurface exported from Arcview wich is a GIS-Tool into dxf. This is imported into blender.
Now i want to place trees onto the landsurface. Is there any way to place the trees automatically on the landsurface.
e.g. select a tree and push a button "snap to surface" then select the surface and then the tree is placed on the surface.
Is there something like this in blender, how difficult would it be to implement this?
regards
clem
ideasman
Post by ideasman »
I dont think this would be that hard to do using a python script.
Have a mesh galld "Land" and any other selected object woul;d be treated as a tree.
A+P Run the magic script.
ANd all trees will move down in the Y until the hit one of "Land"'s faced.
This would be a little tricky - The collision detection bit, but Im sure sombody would help with that if you ask nicely.
zaz
Post by zaz »
The Blender Gamekit book, available in the E-shop here and in bookstores, has a utility that does this. The big caveat is that the game engine is only available right now in versions 2.25 and earlier. The game engine is coming back, but it will be a while before its in a newer released version of blender.
If you know a little python, it'd be pretty easy to use one part of the script in 2.25 and the other part in a current version of blender, making it so you don't need to save your .blend in 2.25 and possibly loose information. If you're already using 2.25 or earlier, you could just run the script. The game engine is necessary for this because it relies on the physics of the game engine to let your objects fall to the ground.
Questions like this are more likely to get answers and more appropriate for http://www.elysiun.com/ The blender.org web site is more for development issues.
clem
Thanks so far
Post by clem »
sorry, but do not know any python. maybe i will get into it.
clem
harkyman
Post by harkyman »
There is this:
http://www.elysiun.com/forum/viewtopic.php?t=20047
But as of yet there is no easy "Drop To Floor" command or script.
Wouldn't be too hard, would it developers?
Developers?
Analogy
Post by Analogy »
Go into editmode for the landscape, select the vertex you want to snap to, shift-S, cursor->selection, get out of editmode, select your tree, shift-S selection->cursor.
Tada!
jesterKing
Site Admin
Post by jesterKing »
Which will put the center of the tree-object on the cursor... So if the object-center is somewhere in the midle of the tree... you'll get not the wanted result.
fligh
Post by fligh »
harkyman
Post by harkyman »
I just wrote a script that places alread-created objects onto a ground mesh. Find it here:
http://www.elysiun.com/forum/viewtopic.php?t=20148
dgebel
Post by dgebel »
Does beast snap to the face's normal or just the surface?
I don't think we have extrude from normal yet, do we?
I've wanted that before more than once.
harkyman
Post by harkyman »
Can't you just make your selection, do an extrude, hit escape, then hit alt-s to move your extrusion along the normal?
tuinbels
Post by tuinbels »
dgebel wrote:I don't think we have extrude from normal yet, do we?
Something like this?
or alternatively, ALT-S scales along the normal: Hit E, then ALT-S,
just depends on what you want to achieve...
harkyman
Post by harkyman »
I've written a python script that will drop selected objects onto a mesh surface.
Here's the thread on elYsuin, where you can read about and download the script:
http://www.elysiun.com/forum/viewtopic. ... highlight=
