Wings 3D Import wanted/needed
Debugnus
Post by Debugnus » Fri Feb 13, 2004 2:49 pm
Hi.. i've a good look at blender (at last) It's all looking great ;)
I'd realy like to see a Wings 3D Import function maybe even an export too... but i like both Blender and Wings 3D, and would like to see how or if they would work together.
:D
..::Debugnus::..
fligh
Post by fligh » Fri Feb 13, 2004 5:29 pm
You can use wavefront obj or 3ds and import/export scripts are availsble at elysiun.
harkyman
Post by harkyman » Fri Feb 13, 2004 5:34 pm
I've used the .obj import/export and it works well. Very easy, too.
What would be phenomenal would be the ability to "flip" a model between the two programs while running them simultaneously. I.e., you're modelling in Wings, hit a special key combo and Blammo! Your Wings model shows up in the current Blender 3d window.
I know this isn't really feasible, but I'm on cold medicine, and it seemed like fun at the time.
emack
Post by emack » Fri Feb 13, 2004 5:49 pm
This is the goal of Verse, if I'm not mistaken . . . the ability to knit disparate apps together quickly. Perhaps a good step would be to write a Verse export plugin for Wings and a Verse import plugin for Blender?
quaestor
Post by quaestor » Wed Feb 25, 2004 3:46 am
fligh wrote:You can use wavefront obj or 3ds and import/export scripts are availsble at elysiun.
Well, speaking as someone who has been trying to do just that, I'd love to know which scripts work with 2.32...
Monkeyboi
Post by Monkeyboi » Wed Feb 25, 2004 10:27 am
Wings import/export would rock. Period
fligh
Post by fligh » Wed Feb 25, 2004 4:55 pm
http://jmsoler.free.fr/util/blenderfile ... odif232.py
quaestor
Post by quaestor » Wed Feb 25, 2004 11:25 pm
Hmmm... Didn't see this one at elysiun...
ideasman
Post by ideasman » Thu Feb 26, 2004 12:17 am
Open up a wings file in a text editor, its a binary file (not plane text) - Like a blend file.
Im not about to decode it, tho its totaly do-able.
If you can stick to the obj format.
fligh
Post by fligh » Thu Feb 26, 2004 5:05 pm
The following answers are provided under GNU liscense and you are free to use them, modify them and distribute them without reference to the original author. However, you are only allowed to use one of those provided and you are obliged to use it only for the relevant and intended purpose:
1) That's obvious.
2) You're not alone.
3) That's what the 'Search' thingy is for.
4) I wonder how the author of the script, after all the time and trouble of writing it, and the generous spirit of making it available, would feel about your response?
5) Nyaa nyaa nya nyaa nyaa...
6) Well now you know.
7) That makes me feel so GOOD!
8) It's not on Elysiun, it's on free.fr
9) Did you look?
10) (and my all-time favourite) This is a development site, you'll get much better response to user questions at www.elysiun.com
dandeloreon1984
Post by dandeloreon1984 » Fri Feb 27, 2004 2:45 am
I found a relevant script here... The only problem is that the script is looking for a matarial.
http://bane.servebeer.com/programming/b ... index.html
The OBJ importer is a little buggy, requires a mtl file....
I reccomend the 3DS, and if you use the 3ds unporter, you may need to rematerial the object.
quaestor
Post by quaestor » Fri Feb 27, 2004 5:57 am
1) That's obvious.
9) Did you look?
?? I guess, since you're a development whiz-kid (since you read and reply to these forae), you don't have time for us lowly users and newbs, who presumably are the reason you exist. Debugnus asked a simple question, and you gave a testy, smart-arsed answer. If you knew the script he was looking for was *not* at elysiun...?? Perhaps if you had taken the time to seriously answer the question, maybe with a relevant link...? In any case, I've found better help, and more polite people, frankly, at elysiun, where I clearly should have stayed. My mistake was in thinking that because I had found *a* pinned thread there about available scripts, I had indeed found *the* current, useful thread about available scripts, perfectly illustrating why I hate relying on forae for support. Now I know, and I have learned.
dandeloreon1984
Post by dandeloreon1984 » Fri Feb 27, 2004 6:05 am
1) That's obvious.
9) Did you look?
Hey I fixed it, since Wings 3d Can Export OBJ, and 3ds File, I say import an 3ds file... OBJ script requires an mtl file...
He is not an wiz kid anyways, he just said look online and search, I say use the mentioned scripts, and do an export and import.
