Background Image Suggestions
ada89
Post by ada89 »
Just simple option like:
Rotate, aspect ratio setting (so you can stretch the bg image etc.) and settable image for deferents side view (I know the split screen method). :D
solmax
Post by solmax »
how about a bitmap mapped to a plane?
neil
Post by neil »
An image mapped to a plane is only available in the textured view whereas a background image should be available in all views (wireframe etc.). I agree these would be nice improvements (and probably not all that difficult although I may be wrong).
Neil.
blendix
Post by blendix »
You can set the object you are creating to be drawn as a Wireframe, in the 'Object Buttons', 'Draw Panel', using the 'Drawtype' dropdown. This way, it will still be a wireframe in Textured View.
If you map the image to a plane, you can naturally do things like rotating, stretching, etc, without having more code and more buttons.
