transform prop. window overlap object name..
jm
Post by jm »
hi
when I minimize transform prop. window it always jump down to the left corner and overlap object name. And I always schould move with it when I want take a look at the name(info). I think that the transf. prop. w. will schould hold on(stand on) in the place where I minimize it.
(the View prop. and the Backgr. prop, is the same)
jm
Carnivore
Post by Carnivore »
I've gotten used to closing it instead of minimizing. I always invoke it with [N] anyway, why minimize?
jm
Post by jm »
when I minimize Transform window in IPO window it overlaps time point(numbers), this isn't also handy.
jm :wink:
ideasman
Post by ideasman »
Might be bettwe if it minimized to the bottom right hand corner.
jd-multi
Post by jd-multi »
Yeah nice idea. If you select a object, you get the name at the lower left of the window, when pressing it, the transform menu pops'up and you can modify it. Would be great, very easy and much cleaner then 2 seperated things. Well I want to see this in a next release. :P
