New OBJ, Import/Export, UPDATE USE MATHUTILS
ideasman
Post by ideasman »
Here are new OBJ importer and exporters.
They dont require any python modules.
Import-
Code: Select all
#!BPY
Blender: 232
Group: 'Import'
Tooltip: 'Load a Wavefront OBJ File'
# OBJ Import v0.9 by Campbell Barton (AKA Ideasman)
# ***** BEGIN GPL LICENSE BLOCK *****
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software Foundation,
# Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# ***** END GPL LICENCE BLOCK *****
WHITESPACE = [' ', '\n', '\r', '\t', '\f', '\v'] # used for the split function.
NULL_MAT = '(null)' # Name for mesh's that have no mat set.
MATLIMIT = 16
# Strips the slashes from the back of a string #
def stripPath(path):
   for CH in range(len(path), 0, -1):
      if path[CH-1] == "/" or path[CH-1] == "\\":
         path = path[CH:]
         break
   return path
# Strips the prefix off the name before writing      #
def stripName(name): # name is a string
   prefixDelimiter = '.'
   return name[ : name.find(prefixDelimiter) ]
# Replace module deps 'string' for join and split #              #
# - Split splits a string into a list, and join does the reverse #
def split(splitString, WHITESPACE):
   splitList = []
   charIndex = 0
   while charIndex < len(splitString):
      # Skip white space
         if splitString[charIndex] in WHITESPACE:
            charIndex += 1
         else:
            break
      # Gather text that is not white space and append to splitList
      startWordCharIndex = charIndex
         if splitString[charIndex] in  WHITESPACE: break
         charIndex += 1
      # Now we have the first and last chars we can append the word to the list
      if charIndex != startWordCharIndex:
         splitList.append(splitString[startWordCharIndex:charIndex])
   return splitList
# Join list items into a string #
def join(joinList):
   joinedString = ""
   for listItem in joinList:
      joinedString = joinedString + ' ' + str(listItem)
   # Remove the first space
   joinedString = joinedString[1:]
   return joinedString
from Blender import *
def load_obj(file):
   # This gets a mat or creates one of the requested name if none exist.
   def getMat(matName):
      # Make a new mat
      try:
         return Material.Get(matName)
      except:
         return Material.New(matName)
   def applyMat(mesh, f, mat):
      # Check weather the 16 mat limit has been met.
      if len( mesh.materials ) >= MATLIMIT:
         print 'Warning, max material limit reached, using an existing material'
         return mesh, f
      mIdx = 0
      for m in mesh.materials:
         if m.getName() == mat.getName():
            break
         mIdx+=1
      if mIdx == len(mesh.materials):
        mesh.addMaterial(mat)
      f.mat = mIdx
      return mesh, f
   # Get the file name with no path or .obj
   fileName = stripName( stripPath(file) )
   fileLines = open(file, 'r').readlines()
   mesh = NMesh.GetRaw() # new empty mesh
   objectName = 'mesh' # If we cant get one, use this
   uvMapList = [] # store tuple uv pairs here
   nullMat = getMat(NULL_MAT)
   currentMat = nullMat # Use this mat.
   # Main loop
   lIdx = 0
   while lIdx < len(fileLines):
      l = split(fileLines[lIdx], WHITESPACE)
      # Detect a line that will be idnored
      if len(l) == 0:
         pass
      elif l[0] == '#' or len(l) == 0:
         pass
      # VERTEX
      elif l[0] == 'v':
         # This is a new vert, make a new mesh
         mesh.verts.append( NMesh.Vert(eval(l[1]), eval(l[2]), eval(l[3]) ) )
      elif l[0] == 'vn':
         pass
      elif l[0] == 'vt':
         uvMapList.append( (eval(l[1]), eval(l[2])) )
      elif l[0] == 'f':
         # Make a face with the correct material.
         f = NMesh.Face()
         mesh, f = applyMat(mesh, f, currentMat)
         # Set up vIdxLs : Verts
         # Set up vtIdxLs : UV
         vIdxLs = []
         vtIdxLs = []
         for v in l[1:]:
            objVert = split( v, ['/'] )
            # VERT INDEX
            vIdxLs.append(eval(objVert[0]) -1)
            # UV
            if len(objVert) == 1:
               vtIdxLs.append(eval(objVert[0]) -1) # Sticky UV coords
            else:
               vtIdxLs.append(eval(objVert[1]) -1) # Seperate UV coords
         # Quads only, we could import quads using the method below but it polite to import a quad as a quad.f
         if len(vIdxLs) == 4:
            f.v.append(mesh.verts[vIdxLs[0]])
            f.v.append(mesh.verts[vIdxLs[1]])
            f.v.append(mesh.verts[vIdxLs[2]])
            f.v.append(mesh.verts[vIdxLs[3]])
            # UV MAPPING
            if uvMapList:
               if vtIdxLs[0] < len(uvMapList):
                  f.uv.append( uvMapList[ vtIdxLs[0] ] )
               if vtIdxLs[1] < len(uvMapList):
                  f.uv.append( uvMapList[ vtIdxLs[1] ] )
               if vtIdxLs[2] < len(uvMapList):
                  f.uv.append( uvMapList[ vtIdxLs[2] ] )
               if vtIdxLs[3] < len(uvMapList):
                  f.uv.append( uvMapList[ vtIdxLs[3] ] )
            mesh.faces.append(f) # move the face onto the mesh
         elif len(vIdxLs) >= 3: # This handles tri's and fans
            for i in range(len(vIdxLs)-2):
               f = NMesh.Face()
               f.v.append(mesh.verts[vIdxLs[i+1]])
               f.v.append(mesh.verts[vIdxLs[i+2]])
               # UV MAPPING
               if uvMapList:
                     f.uv.append( uvMapList[ vtIdxLs[i+1] ] )
                     f.uv.append( uvMapList[ vtIdxLs[i+2] ] )
      # is o the only vert/face delimeter?
      # if not we could be screwed.
      elif l[0] == 'o':
         # Make sure the objects is worth puttong
         if len(mesh.verts) > 0:
            NMesh.PutRaw(mesh, fileName + '_' + objectName)
         # Make new mesh
         # New mesh name
         objectName = join(l[1:]) # Use join in case of spaces
         # New texture list
         uvMapList = []
      elif l[0] == 'usemtl':
         if l[1] == '(null)':
            currentMat = getMat(NULL_MAT)
         else:
            currentMat = getMat(join(l[1:])) # Use join in case of spaces
      lIdx+=1
   # We need to do this to put the last object.
   # All other objects will be put alredy
Window.FileSelector(load_obj, 'SELECT OBJ FILE')
Export -
Code: Select all
#!BPY
Blender: 232
Group: 'Export'
Tooltip: 'Save a Wavefront OBJ File'
# OBJ Export v0.9 by Campbell Barton (AKA Ideasman)
# Gets the world matrix of an object             #
# by multiplying by parents mat's recursively    #
# This only works in some simple situations,     #
# needs work....                                 #
def getWorldMat(ob):
   mat = ob.getMatrix()
   p = ob.getParent()
   if p != None:
      mat = mat + getWorldMat(p)
   return mat
# Apply Transform  #
def apply_transform(verts, matrix):
	verts.resize4D()
	return Mathutils.VecMultMat(verts, matrix)
# Return a 6 deciaml point floating point value      #
# as a string that dosent have any python chars      #
def saneFloat(float):
  #return '%(float)b' % vars()  # 6 fp as house.hqx
  return str('%f' % float) + ' '
NULL_MAT = '(null)'
def save_obj(filename):
   file = open(filename, "w")
   # Write Header
   file.write('# Blender OBJ File: ' + Get('filename') + ' \n')
   file.write('# www.blender.org\n')
   # Get all meshs
   for ob in Object.Get():
      if ob.getType() == 'Mesh':
         m = ob.getData()
         if len(m.verts) > 0: # Make sure there is somthing to write.
            # Set the default mat
            currentMatName = ''
            file.write('o ' + ob.getName() + '_' + m.name + '\n') # Write Object name
            # Dosent work properly,
            matrix = getWorldMat(ob)
            # Vert
            for v in m.verts:
               # Transform the vert
               vTx = apply_transform(v.co, matrix)
               file.write('v ')
               file.write(saneFloat(vTx[0]))
               file.write(saneFloat(vTx[1]))
               file.write(saneFloat(vTx[2]) + '\n')
            # UV
            for f in m.faces:
               for uvIdx in range(len(f.v)):
                  file.write('vt ')
                  if f.uv:
                     file.write(saneFloat(f.uv[uvIdx][0]))
                     file.write(saneFloat(f.uv[uvIdx][1]))
                  else:
                     file.write('0.0 ')
                     file.write('0.0 ')
                  file.write('0.0' + '\n')
            # NORMAL
            for f in m.faces:
               for v in f.v:
                  # Transform the normal
                  noTx = apply_transform(v.no, matrix)
                  noTx.normalize()
                  file.write('vn ')
                  file.write(saneFloat(noTx[0]))
                  file.write(saneFloat(noTx[1]))
                  file.write(saneFloat(noTx[2]) + '\n')
            uvIdx = 0
            for f in m.faces:
               # Check material and change if needed.
               if len(m.materials) > f.mat:
                  if currentMatName != m.materials[f.mat].getName():
                     currentMatName = m.materials[f.mat].getName()
                     file.write('usemtl ' + currentMatName + '\n')
               elif currentMatName != NULL_MAT:
                  currentMatName = NULL_MAT
               file.write('f ')
               for v in f.v:
                  file.write( str(m.verts.index(v) +1) + '/') # Vert IDX
                  file.write( str(uvIdx +1) + '/') # UV IDX
                  file.write( str(uvIdx +1) + ' ') # NORMAL IDX
                  uvIdx+=1
               file.write('\n')
   file.close()
Window.FileSelector(save_obj, 'SELECT OBJ FILE')
oin
Post by oin »
Thanks! Is always very good to have more than one :)
ideasman
Post by ideasman »
Just updated them to fix material bugs... Id like to here if people have any issue with them.
Monkeyboi
Post by Monkeyboi »
These scripts are great! It even tesselates faces with more than four edges! Get these included with the Blender download fast, they are really superb. Good work.
Manuel
Post by Manuel »
I've this error when I try to import a deformed sphere obj previously exported with your export script:
File "obj_import.py", line 166, in load_obj
File "obj_import.py", line 120, in applyMat
TypeError: expected Blender Material PyObject
ciao,
Manuel
ideasman
Post by ideasman »
Fixed, needed to use
change
currentMat = NULL_MAT
to...
Because NULL_MAT is a string.
hanzo
Post by hanzo »
:shock: hey I need this tool, to make somerealy owesome blender games.. model texture ik in maya and export to blender...
can you tell me what this exporter can actualy do? other then meshes
ideasman
Post by ideasman »
AFAIK obj dosent support that many features.
eg, no documentation shows things like lights/bones etc.
Try it- if somthing dosent import/exort
gimmi an example file and Ill have a look and try get it working.
EDIT- I dont think OBJ supports IK- no docs I have read reference this feature.
pildanovak
Post by pildanovak »
it works great for objs exported from SI-xsi, they're just rotated 90 degrees around the x axis. Thanks much
oin
Post by oin »
Thanks to you Ideasman :) I have not tested, but I'll surely use it a lot :)
I'm all the time using OBJ as my workflow is based in complex workflows, not a single software (Wings3d, Ultimate Unwrap, Character Fx, Anim8or, Blender, etc)
And for what i have seen as an artist , OBJ support :
-smoothing normals info. (I think smooth groups but also an autosmooth value (like90º, 75º, 60º, etc), the angle threshold that decides if an edge is creased in the shading or not )
-complex Materials : difusse, specular, bump, opacity, maps(textures) and its settings. Material color, (not vertex colors) , emisive values (like a self ilumination material setting) , diffuse color, ambient color. UV coords.
All this are specified in an ascii file called *.mtl. Is a simple collection of values for settings. Also , OBJ are ascii files. usually a coords list , with some like flags "vt" (textured vertices) , s (smooth group I think, all the following coords will be possible an smooth group) , g (for group) , etc.
It does not support bones(so neither weights.No either any form of animation). Not lights. I am almost sure neither cameras (one I can remeber that does is ASE, Ascii Scene Exporter for max, and possibly VRML2 ) Not vertex colors. But supports quads (while x, wrml doesn't)
It supports large geometry files.
IMHo, OBJ is one of the most standard and solid static formats out there. A life saver for conversions. Usually is the most problem free. So, cheers for all the OBJ plugins for Blender :)
matt_e
Post by matt_e »
Works great importing from ZBrush 1.55, too. Again it's rotated, but I can deal with that :). It seems a bit slow though - that mesh (although it's quite large - 95,000 verts) took about 2 minutes to import on this G4, 1.25Ghz / 1GB RAM.
halibut
Post by halibut »
It's rotated blender uses the z axis as upwards (height), whereas most you it as going backwards (depth), at least I think that's the case, or something similar.
jiri
Post by jiri »
it doesn't import/export mtl file! Why?
soletread
Post by soletread »
I am looking forward to using this script, unfortunately it crashes blender if I try to export an object that is in a scene shared with other objects.
If I have only one object in the scene then it exports nicely...
Windows XP
Blender 2.33
cheers....
ideasman
Post by ideasman »
Yeah, I have had segfults for no apparent resion.
The string splitting for the importing has been rewritten to use pythons internal split function. (I wasnt aware of it at the time of writing)
About MTL files- SMTD (Show Me The Docs)
Could sombody please send some complex OBJ scenes with as many odd OBJ functions as possible.
I havnt been able to find an obj sample on the net that even uses an MTL file.
- Cam
