Rammu!
Is there a feature for making semi-transparency of objects in the 3-d view (in "object mode")? like, if i want to see the object faintly, but not be able to click on it while working with other objects?
/Katt
Semi-Transparency
if you create a new "Scene" (up to the right in 3D window, "Add New") and link it in via renderwindow settings, in the panel "Output" you see a doublearrow up/down under [ /ftype ] click on those arrows (dropmenu) to select a scene to be linked in...
other than that I don't know how,
but I have suggested long ago making Layers non-editbable, like "greyed" out, visulized, but not abled to be edited...
good luck
good luck
