RFC: NEXT-Like File Browser
aqsalter
Post by aqsalter »
Would it be possible to add a 'NEXT'-like (ie OSX-like ;) file browser functionality to the standard file browser for Blender?
This would greatly increase the browsing speed.
Thanks,
Adam
z3r0_d
Post by z3r0_d »
what are you talking about?
the osx file browser has several different layouts that all act differently, can you at least pick one?
matt_e
Post by matt_e »
I think he means the 'Columns' view, where you navigate horizontally (kinda like the iPod interface actually...). It evolved from the NeXT OS. now coding something like that is another thing altogether :)
Monkeyboi
Post by Monkeyboi »
A revision of the File Browser is a good idea nonetheless. a [..] sign is just not a standard way no navigate back and [.] is not a standard for reloading. It could do with agood overhaul - it has hardly been changed since Blender 1.7. Many of its features are also very hidden, and the way you select several files at once is not obviouos. IMO the File Browser needs a revision from the ground up.
I love the NeXT-style filebrowser that is in OSX, but I, like Broken, can imagine it might be hard to implement.
lukep
Post by lukep »
broken wrote:I think he means the 'Columns' view, where you navigate horizontally (kinda like the iPod interface actually...). It evolved from the NeXT OS. now coding something like that is another thing altogether :)
actually coding that is not that hard IMHO (I have done something similar whith an array of lists of dir entries).
However, if I like this type of browser (I use almost only this view), I'm not sure it is needed to impose that to others platforms. If it is handy, you need some knowledge of it to be confortable with.
The blender browser lacks perhaps in the fancy department, but works flawlessly.
gabio
Post by gabio »
i dont see too much probleme with the current filebrowser execept the fact 3/4 of the fuctonnality is hiden. move, copy, delete a file is not very easy to find... maybe a file menu in the header bar or something.
Also the fact we still get some "/" stuff on windows. it work but not with volum setup. why not just code the filebrowser to get the drive letter at load, instead of selecting it in the pulldown to pass from / to c:\...
joeri
Post by joeri »
Anyone starting to code in the fileselect can get into mayor trouble.
/, // and \ . \n, /n and \\ and | are all fun in sgi based program converted to all OS.
And, it's everywhere: Liblink, Texures, Text, even in the packed files.
At some point I thought it would be best to use the OS native fileselect. Because users of their OS most of the time like the FS they have. And it saves alot of time writting features like thumbnail view.
I mostly work on windows with drives on other machines named something like: \\bigwhale\render disc\ and I hate to have to map them all the time :wink:
aqsalter
Post by aqsalter »
First I think this type of file browser would be the easiest of any type to implement as it is basically just breaking up the browser window with multiple levels of file lists - A windows explorer type (with the little "+" to open subfolders) would be much more difficult.
I chose this type because I thought it would integrate nicely, be great and easy to implement as well.
Second, it wouldn't have to be a matter of imposing on others. The default could be to leave the view the way it is, and have a button to toggle between views (it would just add a slider to the bottom of the window as well).
Third, I just realised, on windows the root could show the drives (A,B,C etc) so that people could easily navigate to other drives.
<shrug> I certainly think it would improve file browser useability.
