importing objects into a scene
multix
Post by multix »
What would be a good way to import one object (composed of several different items) into another scene ?
I tried using the append command, but I end up needing to import every single element (say left arm, right arm, head...)
Suggestions to make this cleaner? At the end I need to build a small libraries of objects that can be imported effortless in a scene
zbgump
Post by zbgump »
You can select all your objects at once and append them in one shot.
You can right-click and select multiple objects individually or you can hold right-click and drag to quickly select many.
