Page 2 of 2
Posted: Mon Dec 06, 2004 7:32 pm
by Bellorum
Why do you have to confirm when deleting a vertex anyway(Theeths proposal)? Having one option is not an option :wink: Besides, now that we have proper undo functionality, we can just hit ctrl-z if we make a mistake, right?:)
Posted: Tue Dec 07, 2004 3:53 pm
by Kenden
Bellorum: good point!;)
Matt, I looked a bit more at your proposal, at the option "Erase: Edge".
Description: "Should also automatically remove shared vertices in between selected edges".
I think this could be a problem with a mesh like the one in the picture below: if you delete the two selected edges and the shared vertex in between, you will delete all the faces at the top, which is probably not what you want (or is it?).
Image--->Image
So maybe a better rule could be:
Erase: Edges:
Should also automatically remove shared vertices in between selected edges if those vertices are shared with maximum one other edge.
Posted: Tue Dec 07, 2004 5:48 pm
by tommy
Kenden wrote: tommy, the extrude system is already implemented this way (different extrude options depending of the mode), so it seems logical to do the same with delete.
...exactly what I mean! :D - however, it would also be nice to have extrude vertex/edge similar to the Wings does it, as an option.
Another thing, before I go off on a tangent completely, it would be handy to be able to create objects on an object's surface - and no I don't mean turning DupliVert objects into real ones... (that's already available, or at least has been in a past release a few years ago).
Posted: Tue Dec 07, 2004 10:37 pm
by theeth
Kenden wrote:Bellorum: good point!;)
Image--->Image
Erase: Edges:
The deletion code when using the Edges option already takes care of that potential problem, so this is not really an issue. Thanks anyway. :)
