Flipping normals won't work
cross
Post by cross »
Hello everyone,
I'm new to Blender and I've just downloaded and installed version 2.36 running on Linux, Fedora Core 2 with GNOME. I'm having problems constructing the 'Gus' character presented in the manual. Specifically, When I try to create the left side of the body by duplicating and flipping the right side I get no result.
Here's what I've tried:
1) Build right side as per instructions
2) Select all verticies (KEYA)
3) Select 3D cursor button
4) Duplicate selected verticies (KEYD)
5) Select scaling (KEYS)
6) Flip on X (KEYX)
7) Finish (both ENTER and LHM have been tried)
I've tried this numerous times with no result. Does anyone have suggestions?
Thanks in advance,
Cameron.
joeri
Post by joeri »
Mirror has changed to CTRL-M.
More changes and additions can be found here:
http://www.blender3d.org/cms/Releaselogs.34.0.html
Rahu
Post by Rahu »
ctrl+m in object mode or m in edit mode.
theeth
Post by theeth »
Ctrl-M works in edit mode too. Simply M is only kept for backward compatibility and might be droped in the future if we need the key for something else.
Martin
- John Lennon
joeri
Post by joeri »
theeth wrote:Ctrl-M works in edit mode too. Simply M is only kept for backward compatibility and might be droped in the future if we need the key for something else.Martin
I'd say remove it. SX is also not kept for backward compatibility.
