Question using Armatures
KungFooMasta
Post by KungFooMasta »
I did the tutorial modelling an arm and using armatures with bones and things, but I'm trying to make my own basic model, and I can't create any armatures. All I have done is taken the box given in a new project and made a cross. I want to create an armature so I can put in bones and try and make basic animations with this cross-like figure. What needs to be done to be able to add an armature? I created the cross, and I left clicked somewhere, pressed spacebar, and the option wasn't available to add an armature. =(
Delta
Post by Delta »
if you see the verts of your mesh, then press [tab] to get out of edit mode and then press [spacebar]->[add]->[armature] etc. etc. etc.
by the way, this is a developer's forum. that means that you'd do better off asking questions in a user's forum like elYsiun or something
i hope this helps
Regards,
~Delta
KungFooMasta
oops! I feel retarded. That was it...
Thanks!
