Page 1 of 2
Feature proposal Updated
Posted: Fri Jul 15, 2005 11:19 pm
by ElBarto
Hello,
after a long time i updated my feature proposal. I recognized that a lot of these things come true and Blender is better then ever!
Thanx for it.
I added a new chapter about merge options of vertex points:
http://www.neeneenee.de/blender/features/#26
Posted: Sun Jul 17, 2005 12:53 am
by z3r0_d
does the V key do anything in edit mode?
why isn't merge [at center] the V key like it is in the uv editor?
Posted: Sun Jul 17, 2005 9:58 am
by ElBarto
...mhm, not a bad idea having merge menu on V! Can't see that V has a function in editmode (once it was direct change to vertex pint mode).
Posted: Tue Jul 26, 2005 10:57 pm
by ElBarto
A new chapter added to my feature proposal, it is about adding properties and dnymic panels:
Adding properties and stacks
http://www.neeneenee.de/blender/features/#27
Posted: Wed Aug 03, 2005 11:49 pm
by ElBarto
After all discussions i'm a fan of a cleaner and more uniform interface. I think the idea of moving color sliders into the color picker dialogue would be really fine.
I added the example that shows a fine and clean Yafray Mirror Transp Panel instead off what we have now:
Cleaner interface and better color picker
http://www.neeneenee.de/blender/features/#24
Posted: Thu Aug 04, 2005 12:15 am
by ElBarto
I realized i forget the material panel, so one more picture for this. I added at the color picker dialogue with the possibility to copy and paste colors to/ from clipboard.
Posted: Thu Aug 04, 2005 8:06 pm
by ElBarto
In addition of the feature of the compression of files i updated my proposal:
Save files compressed
http://www.neeneenee.de/blender/features/#12
BTW: There are buttons at the save dialogue like "Releatives Path" and "Loading UI" that comes from the open dialogue.
Posted: Fri Aug 05, 2005 12:07 am
by Blendorphin
ElBarto wrote:I realized i forget the material panel, so one more picture for this. I added at the color picker dialogue with the possibility to copy and paste colors to/ from clipboard.
You might want to take a look at the Buttons Information Architecture section in the BlenderDev wiki; the RGB sliders are being removed as you suggested in the new buttons layout.
Your idea of having the RGB sliders in the picker is good though.
Posted: Fri Aug 05, 2005 7:17 pm
by ElBarto
Ahh, great to see Blender is geting better and better.
A feature that i dreamed too of the color picker is the possibility to copy and paste color:
Posted: Fri Aug 05, 2005 10:52 pm
by guitargeek
If you hover over a color (without going to the picker) and press CTRL-C then go to another color bar, you can press CTRL-V to cut and paste the color already.
Posted: Sat Aug 06, 2005 10:50 am
by ElBarto
Thanx for the hint, but that is typical for Blender, there is a function but there is no hint or GUI element to use it.
May a copy and paste button would make this more clear ;)
Thanx.
Posted: Mon Aug 08, 2005 8:26 pm
by theeth
ElBarto wrote:Thanx for the hint, but that is typical for Blender, there is a function but there is no hint or GUI element to use it.
Since Ctrl-C/V works with all the buttons, adding copypaste buttons would be tricky.
Posted: Mon Aug 08, 2005 11:36 pm
by ElBarto
But it is usefull adding it at the color picker :) and the Tooltip for a color field could be: "RGB: 0.80 0.80 0.80 - Ctrl+C for copy and Ctrl+V for paste"
Posted: Mon Aug 15, 2005 12:24 am
by ElBarto
Just cosmetics for the modifier stack - left side current CVS, right side a cleaner modifier stack:
Posted: Wed Aug 24, 2005 9:33 pm
by ElBarto
Notes/ Annotation for objects
I renembered in 3dsMax you can leave notes directly on the properties of an object.
In Blender an Empty object has mostly a special task and after sometimes a project is over it is hard to remember what the special task of an empty was.
So it would be nice if an Empty object has a Notes field at the panel "Links and Materials:
Or have a special Notes panel for every object.
It would be very cool too have a python access to this Notes field for exporting the content of it too (may as annotation or for non supported features).
