change Scene shortcut
kxs
Post by kxs »
What do you think about change Scene shortcut? I think that Alt+left or right cursor would be good choice as Ctrl+left or right cursor changes Screens.
joeri
Post by joeri »
I think you'll find ctrl is used as 'do' and alt is used as 'undo'.
So 'do' scene scenes should be ctrl.
kxs
Post by kxs »
joeri wrote:I think you'll find ctrl is used as 'do' and alt is used as 'undo'.
sorry, but I guess I didn`t understand what you are saying. I was talking about asigning Alt+left or right cursors to changing Scenes. it can`t be Ctrl, because it changes/toggles Screens.
sorry if my english isn`t good enough :oops:
ideasman
Post by ideasman »
I solution could be to have a Prev/Next for EVERY datatype- Text/Image/Mesh/Scene etc. That way you could switch all datablicks without having to manually select.
joeri
Post by joeri »
That would take up an extra keyboard :)
kxs
Post by kxs »
but Alt+left or right cursor doesn`t have any assigned action. so you don`t need new keyboard.
it would be great if I didn`t had to select Scene from the uper menu and could just toggle Scenes just like Screens with Ctrl. don`t you think it would be helpfull?
joeri
Post by joeri »
I'd rather have the window type changed with alt-left and alt-right.
But sure, SCE change is an option as well. Although you can make SCR with a SCE and swap SCE by swapping the SCR.
ideasman
Post by ideasman »
joeri wrote:That would take up an extra keyboard :)
If you where refering to my comment- I was thinking of 2 small buttons next to the cross- so you could cycle through datablocks,
As key shortcuts it wouldent realy work. - I should have mentioned that tho
- Cam
joeri
Post by joeri »
Sorry I forgot to quote you, but I was refering to your comment.
Sometimes the popuplists get to long and a cycle would help.
