Subsurf Optimal, smoothing or straightening loops
kellymandrake
Post by kellymandrake »
The problem I am haveing is while working with subsurf on and optimal on, moveing individual verticies. Sometimes I get a situation like below where i have a curve or loop that I want to straighten out, mostly this hapened a few times and by moveing the sorounding verts I was able to corect the probglem, but in this particular case it seems I cannot straighten it out nomater what I try.
For this I need a solution, the problem area circled.
fligh
Post by fligh »
How many Fgons do you have in there?
tommy
Post by tommy »
Sometimes it's necessary to toggle out of subsurf mode and see what the low-res cage actually looks like. This is what I do whenever I get something like that, especially when working in optimal mode. It can sometimes create a completely false image of what the mesh topology looks like.
Edit: One thing I also noticed about your mesh is that it's not one, but two objects, one of which is mirrored. It's normal for non-manifold vertices to be slightly off when subsurfed.
