DupliFaces
malefico
DupliFaces
Post by malefico » Sat Oct 29, 2005 8:38 pm
Hi, I propose this new feature. It is the same as DupliVerts, but instead of duplicating at vertices, it would be duplicating at faces center locations.
Option "Rot" should work almost the same but aligning object to face normals instead of vertex normals when using DupliFaces.
Even more, both Dupliverts and Duplifaces, should be able to work only on selected vertices/faces too.
These features would help newcomers which are not very used to work with Python scripts or do not master Particle systems (which are the current most common workarounds AFAIK).
Best regards
malefico.
