What is the structure of a *.blend file?
thethekornerr
Post by thethekornerr »
I want to build a model in Blender and get it to my engine.
I need vertex info.
Where can I get info on *.blend file?
Or maybe any simpler format which Blender supports.
Thanks.
lightning
Post by lightning »
You would be better off using the .obj format, if you just need vertex/face information. Blender will export, it is in the scripts window.
There is an article here that has a brief summary of the format. It's pretty easy, you shouldnt have any trouble.
The dawn of a new error...
thethekornerr
Thanks.
thethekornerr
Does *.obj supports textures?
If not, which format do you advise to use?
I need not only vertex info (as I thought before), I need a whole model to export to own engine.
So which one is the easiest? And info?
Thanks.
an-toni
Post by an-toni »
.blend is definitely not easiest, but thought it might be interesting for you / record to know that iirc CrystalBlend reads it - if your engine is in c++ to you might be able to reuse the code there
but yep, usually ppl export to diff formats for game engines (many engines seem to have their own)
~Toni
thethekornerr
If I make my own format, then I'll be unable to use Blender for creating models. Or at least I'll have to write script (and I don't know Python AT ALL).
So which one can you advise me to use? And info?
Thanks.
zupermonkey
Post by zupermonkey »
I have learned Python in 0:30 minutes...
It is not hard, especially if you can already program in another language like C or C++.
jesterKing
Site Admin
Post by jesterKing »
thethekornerr wrote:If I make my own format, then I'll be unable to use Blender for creating models. Or at least I'll have to write script (and I don't know Python AT ALL).
Thanks.
Pick any of the gazillion existing formats... Less grey hairs for yourself, too :)
/Nathan
joeri
Post by joeri »
jesterKing wrote:Pick any of the gazillion existing formats... Less grey hairs for yourself, too :) /Nathan
I think the question is: which of the formats that blender exports includes the models data and textures uv-coordinates and textures name.
so, I made a cube, slapped a texture on one face, and made an export from them all. Here are the results:
Code: Select all
AC       Data, UV Coordinates, Texture Name  (ascii)
OBJ      Data, UV Coordinates, Texture Name  (ascii)
WRL      Data, UV Coordinates, Texture Name  (ascii)
X3D      Data, UV Coordinates, Texture Name  (ascii)
X        Data, UV Coordinates (ascii)
LWO      Data, UV Coordinates (bin)
WINGS    Data , UV? (bin)
NDO      Data (bin)
OFF      Data (ascii)
CAL      Data, UV, Texture all in a bunch of xrf and xmf files.
joeri
AC
Post by joeri »
AC wrote:AC3Db
MATERIAL "DefaultWhite" rgb 1 1 1 amb 1 1 1 emis 0 0 0 spec 0.5 0.5 0.5 shi 64 trans 0
MATERIAL "Material" rgb 0.756191 0.756191 0.756191 amb 0.5 0.5 0.5 emis 0 0 0 spec 1 1 1 shi 32 trans 0
OBJECT world
kids 1
OBJECT group
name "Cube"
kids 2
OBJECT poly
name "Cube_0"
data 4
Cube
crease 30
numvert 8
1 -1 -1
1 -1 1
-1 -1 1
-1 -1 -1
1 1 -0.999999
0.999999 1 1.000001
-1 1 1
-1 1 -1
numsurf 5
SURF 0x00
mat 1
refs 4
0 0.0 1.0
1 0.0 0.0
2 1.0 0.0
3 1.0 1.0
SURF 0x00
mat 1
refs 4
0 0.0 1.0
4 0.0 0.0
5 1.0 0.0
1 1.0 1.0
SURF 0x00
mat 1
refs 4
1 0.0 1.0
5 0.0 0.0
6 1.0 0.0
2 1.0 1.0
SURF 0x00
mat 1
refs 4
2 0.0 1.0
6 0.0 0.0
7 1.0 0.0
3 1.0 1.0
SURF 0x00
mat 1
refs 4
4 0.0 1.0
0 0.0 0.0
3 1.0 0.0
7 1.0 1.0
kids 0
OBJECT poly
name "Cube_1"
data 4
Cube
texture "/IMG_0585.jpg"
texrep 1 1
crease 30
numvert 4
1 1 -0.999999
0.999999 1 1.000001
-1 1 1
-1 1 -1
numsurf 1
SURF 0x00
mat 1
refs 4
0 0.0 1.0
3 0.0 0.0
2 1.0 0.0
1 1.0 1.0
kids 0
OBJ wrote:# Blender OBJ File: g:/10YEARS/2.Menu/source/cd.blend
# www.blender.org
mtllib test.mtl
o Cube_Cube
v 1.000000 1.000000 -1.000000
v 1.000000 -1.000000 -1.000000
v -1.000000 -1.000000 -1.000000
v -1.000000 1.000000 -1.000000
v 1.000000 0.999999 1.000000
v 0.999999 -1.000001 1.000000
v -1.000000 -1.000000 1.000000
v -1.000000 1.000000 1.000000
vt 0.000000 1.000000 0.0
vt 0.000000 0.000000 0.0
vt 1.000000 0.000000 0.0
vt 1.000000 1.000000 0.0
vn 0.577349 0.577349 -0.577349
vn 0.577349 -0.577349 -0.577349
vn -0.577349 -0.577349 -0.577349
vn -0.577349 0.577349 -0.577349
vn 0.577349 0.577349 0.577349
vn -0.577349 0.577349 0.577349
vn -0.577349 -0.577349 0.577349
vn 0.577349 -0.577349 0.577349
usemtl Material
f 1/1/1 2/2/2 3/3/3 4/4/4
f 5/5/5 8/6/6 7/7/7 6/8/8
usemap (null)
f 1/9/9 5/10/10 6/11/11 2/12/12
f 2/13/13 6/14/14 7/15/15 3/16/16
f 3/17/17 7/18/18 8/19/19 4/20/20
f 5/21/21 1/22/22 4/23/23 8/24/24
and a MTL file wrote: # Blender MTL File: g:/10YEARS/2.Menu/source/cd.blend
newmtl Material
Ns 96.0784313725
Kd 0.756191 0.756191 0.756191
Ka 1.000000 1.000000 1.000000
Ks 1.000000 1.000000 1.000000
d 1.000000
illum 2
WRL wrote: #VRML V2.0 utf8
# This file was authored with Blender (http://www.blender.org/)
# Blender version 237
# Blender file g:/10YEARS/2.Menu/source/cd.blend
# Exported using VRML97 exporter v1.50 (2005/06/03)
NavigationInfo {
headlight FALSE
visibilityLimit 100.0
type ["EXAMINE", "ANY"]
avatarSize [0.25, 1.75, 0.75]
Background {
groundColor 0.057 0.221 0.4
skyColor 0.057 0.221 0.4
DEF Cube Transform {
translation 0.0 0.0 0.0
children [
Shape {
appearance Appearance {
material DEF MA_Material Material {
diffuseColor 0.756 0.756 0.756
ambientIntensity 0.25
specularColor 0.478 0.478 0.478
emissiveColor 0.0 0.0 0.0
shininess 0.196
transparency 0.0
texture DEF IMG_0585_jpg ImageTexture {
url "IMG_0585.jpg"
geometry IndexedFaceSet {
solid TRUE
coord DEF coord_Cube Coordinate {
point [
1.0 -1.0 -1.0, 1.0 -1.0 1.0, -1.0 -1.0 1.0, -1.0 -1.0 -1.0, 1.0 1.0 -1.0, 1.0 1.0 1.0, -1.0 1.0 1.0, -1.0 1.0 -1.0,
coordIndex [
0 1 2 3 -1, 4 7 6 5 -1, 0 4 5 1 -1, 1 5 6 2 -1, 2 6 7 3 -1, 4 0 3 7 -1,
texCoord TextureCoordinate {
point [
0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0,
texCoordIndex [
0, 1, 2, 3, -1, 4, 5, 6, 7, -1, 8, 9, 10, 11, -1, 12, 13, 14, 15, -1, 16, 17, 18, 19, -1, 20, 21, 22, 23, -1,
X3D wrote: <?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE X3D PUBLIC "ISO//Web3D//DTD X3D 3.0//EN" "http://www.web3d.org/specifications/x3d-3.0.dtd">
<X3D version="3.0" profile="Immersive" xmlns:xsd="http://www.w3.org/2001/XMLSchema-instance" xsd:noNamespaceSchemaLocation="http://www.web3d.org/specifications/x3d-3.0.xsd">
<head>
<meta name="filename" content="g:/10YEARS/2.Menu/source/cd.blend" />
<meta name="generator" content="Blender 237" />
<meta name="translator" content="X3D exporter v1.50 (2005/06/06)" />
</head>
<Scene>
<NavigationInfo headlight="FALSE" visibilityLimit="100.0" type="EXAMINE, ANY" avatarSize="0.25, 1.75, 0.75" />
<Background groundColor="0.057 0.221 0.4" skyColor="0.057 0.221 0.4" />
<Transform DEF="Cube" translation="0.0 0.0 0.0">
<Shape>
<Appearance>
<Material DEF="MA_Material" diffuseColor="0.756 0.756 0.756" specularColor="0.478 0.478 0.478" emissiveColor="0.0 0.0 0.0"
ambientIntensity="0.25" shininess="0.196" transparency="0.0" />
<ImageTexture DEF="IMG_0585_jpg" url="IMG_0585.jpg" />
</Appearance>
<IndexedFaceSet solid="true"
texCoordIndex="0, 1, 2, 3, -1, 4, 5, 6, 7, -1, 8, 9, 10, 11, -1, 12, 13, 14, 15, -1, 16, 17, 18, 19, -1, 20, 21, 22, 23, -1, "
coordIndex="0 1 2 3 -1, 4 7 6 5 -1, 0 4 5 1 -1, 1 5 6 2 -1, 2 6 7 3 -1, 4 0 3 7 -1, ">
<Coordinate DEF="coord_Cube"
point="1.0 -1.0 -1.0, 1.0 -1.0 1.0, -1.0 -1.0 1.0, -1.0 -1.0 -1.0, 1.0 1.0 -1.0, 1.0 1.0 1.0, -1.0 1.0 1.0, -1.0 1.0 -1.0, " />
<TextureCoordinate point="0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, 0.0 1.0, 0.0 0.0, 1.0 0.0, 1.0 1.0, " />
</IndexedFaceSet>
</Shape>
</Transform>
</Scene>
</X3D>
