Constraints -Local Settings and Negative influence
[kothe]
Post by [kothe] »
I have started to use constraints to animate some objects and it's realy a powerful tool. BUT, It's sad that you only are able to set the some settings global. If I for example would like to animate a couple of gearwheels, I would like to be able to connect them all to the same empty but give the half of them a negative influence ( -1 ) and be able to put them in a ring around the x-axis but still want them to react around there local y-axis.
A'm I making a clear point here or do I need to post some images?
//Kothe
ROUBAL
Negatives constraints and Local/global choice
Post by ROUBAL »
I totally agree with you.
I'm pleased to read that I'm not alone with my wish! :D
I have exactly the same request since I have started to use blender 3 years ago...
Here is what I have posted on Blenderartists some times ago:
Hi !
I have a wish for a little thing that I have asked for, for a very long time. It seems simple but has not yet been included :
Adding Negative constraints to Copy Rotation and Copy Location constraints.
3 more small buttons with -X -Y -Z...
They would be very usefull in many animations for the poor non-coders like me !
One more button for the choice Local/Global, usable for objects would be great , because now we have to use one bone as parent for an object if we want to use a local axis constraint on this object, and it is not handy.
Being able to have on objects the same control as on bones would be a good thing.
For example for gear wheels at 90°...
But as bones use Quaternions for rotation instead of XYZ coordinates, I don't know if this can be easily done for objects...
I have never been able to write a single line in Python, and I have often to add a lot of empties and extra bones to achieve a result that could be got with a simple button.I have only programmed few things in Quick Basic about 20 years ago, but I guess that creating negative constraints would only need to copy some lines and add a negative sign somewhere...
I hope that somewhere, a god of coding will hear me !o)
Thank you in advance !
Philippe.
LetterRip
Post by LetterRip »
contact aligorith - he probably would be willing and able to add such...
LetterRip
ROUBAL
Post by ROUBAL »
Thanks LetterRip !
