Mesh Modifier Nodes? Just a thought...
Ammusionist
Post by Ammusionist »
With the incredible versatility just starting to come into play from Material and Rendering nodes, I was wondering if anyone had thought about shifting the mesh modifier stack to the node system as well?
ZanQdo
Post by ZanQdo »
So you are saying something like using two modifiers conected by a mix node? wierd, can you give a real example? I know it sounds cool but it´s hard for me to think in a real use for this.
:-) Hosting for your test builds:
GraphicAll.org
aligorith
Post by aligorith »
Just hijacking this thread...
It appears to me that IPO drivers are an intermediate step that pave the way towards having Node controlled Armature rigs, etc.
Just a thought...
Aligorith
Ammusionist
It'd be great for all the node systems to have a value from frame range generator node:
Parameters:
- Start Frame
- End Frame
- Min Value
- Max Value
It'll act like a linear IPO with 2 points - Stays at Min till Start Frame, then moves from Min to Max until End Frame then stays on Max frame after.
Hmmm - That's reinventing the wheel isn't it.
How about have an IPO driven value node! (Perhaps with a scale and offset parameter)
jesterKing
Site Admin
Post by jesterKing »
I'm currently working on pyNodes - nodes that are controlled by scripts. I don't see a reason to not be able to use the cfra & co data.
Actually, I might just do a test with it right now to see if it really works already with my current WIP :)
/Nathan
matt_e
Post by matt_e »
Ammusionist wrote:It'd be great for all the node systems to have a value from frame range generator node:
There is a 'time node' at least for the compositing system. Contains a curve, like the RGB curves.
