Hi all,
Does blender allow one to export to eps (or is there a way to do so) so that I can include images in a latex document? Another way would be to export to tex, allowing me to use PSTricks to render in latex.
Thanks,
Paulo Matos
Exporting to EPS for Latex inclusion
render as png then use a utility to convert png to eps such as
http://bmeps.sourceforge.net/usage.html
LetterRip
LetterRip
You could write a script to render the geometry to PostScript or another vector format, if you didn't want to render to a bitmap then try to convert that to Postscript. The problem is if you want lighting, textures, etc.-- then you'd basically be implementing your own renderer! But if you just want a line drawing then it's pretty easy, just project the geometry. Doing some simple flat shading might not be so bad. But beyond that (textures, effects, etc) you're looking at a much bigger project.
I don't know anything about Yafray though, or about Blender's external renderer support in general. It's possible that there is a way to hook in an existing 3D-to-2d-ps renderer of some kind.
If you're on Linux, you could check this: http://www.vizzy.de/index.php?i=verblender
Hopefully we will see this Vector Output of 3DView (EPS/SBG/PDF) implemented on all platforms.
