how usage of "center point"(pink Dot) if ....
Posted: Fri May 26, 2006 10:20 pm
by pong
first, i'm new user try to be a power. :P and not good at English
i confused that sometimes i deleted object (ALL) in EditMode .
the object is deleted, but not a Pink Dot (object Center).
and hard to delete it
or it is useful for another way?
here is my Detail:
1. Ctrl-x to create New with a Cube selected.
2. tab to EditMode,object still selected shown in Yellow Dots and Lines
3. x to Erase > All
4. object deleted. but not its Pink Dot. and cannot select
5. tab back to ObjectMode, pink dot is Selected , and could Delete now.
But If we turn to select another object say Lamp, then we could not select the pink Dot again. (Right Click,Box selection)
6. after a several try. i found only way to select it back is" Lasso" Ctrl-LMB
have to take times because Lasso Select is not mention in any Basic Chapter of Blender.
that's all to Know Why the Pink Dot did not Erase along with its object.
or it useful for....i don't know
sorry if this is a stupid Question.
Posted: Sun May 28, 2006 11:11 pm
by solmax
ok, here is the solution:
you were in edit mode and deleted all vertices, edges and polys. still, there is the "object". think of it a as container for the actual mesh data. it can be empty, and this is your case. to delete a whole object, tab out of edit mode and press "Del" or "X".
so it also makes a difference. if you add a mesh during edit mode or during object mode. say you have just created a cube, are still in edit mode and add a sphere - you will end up with an object consisting of a cube and a sphere. if you need separate objects, always leave edit mode after you created an object.
hope this was clear :)
Posted: Mon May 29, 2006 7:06 am
by pong
i make a presentation (580kb size) for clearly my Asking
that a Center Point confused me.
http://www.f-forge.com?d=2LxrWQyuIoGYsevRnf0h
please Extract the Zip and try "PinkDot.htm"
thanks
Posted: Fri Jun 09, 2006 10:31 pm
by pong
solmax wrote:ok, here is the solution:
thanks for answer but sorry, i think it's not the answer of my asking.
1.I know that object added in Edit mode Would be merge to one object
( means Share the Center Point )
2.Yes,No problem When Delete Object in Object mode, But there was a problem when we hit X > Erase All in Edit Mode
it's about remaining unuseful several Pink Dot(object Center,not vertice)
i don't find any useful of the junk Center Dot .
please Try my presentation in the Above comment. for Cleary my description
Posted: Mon Jun 12, 2006 8:02 pm
by z3r0_d
you're saying deleting all verticies in an object should delete the object itself?
Posted: Tue Jun 13, 2006 6:01 pm
by pong
z3r0_d wrote:you're saying deleting all verticies in an object should delete the object itself?
I know that Delete in Object Mode Will Delete All Vertice.it's right.
But
1 Delete All Select in "edit Mode"
2.will Leave a Pink/white(Center) Dot.
3.tab out to object Mode, Then A to Deselect all.
4. now You could not select it again,
only "Lasso Select" in Object mode could Do this
Just want to know if i leave These many Dot on screen. how this Useful?
have you try to watch my upload file , it's just 580 kb.
it will cleary,or not?
:shock:
