Outliner needs horizontal scroll
aligorith
Post by aligorith »
Unless I'm totally missing something here, the outliner needs horizontal scrolling. Currently, it can only scroll vertically.
No horizontal scrolling is ok, as long as your object names are short, you are not viewing stuff that is several layers deep (i.e. armature bones are one example), you have a wide (and possibly dedicated) monitor for it.
Should be relatively simple to do, I think.
Aligorith
aligorith
Post by aligorith »
I see that nobody has responded to this yet, so some questions:
How is the vertical scrolling accomplished now?
Does the outliner_height function have any part to play in this (I'm guessing it does, in which case something similar would need to be concocted for horizontal scrolling)
What are the OL_H and OL_X values for?
Aligorith
Auralis
Post by Auralis »
Not only a horizontal scrol, but a better vertical scroll as well.
In fact all scrolls do suck in blender.
aligorith
Post by aligorith »
I see that in the code, the outliner at some stage had code that made it scrollable two-ways, but that code is commented out, and the current style in use is the single L_Scroll.
Does someone know why this change was made?
I'm guessing it might have something to do with the possibility that the code to do so wasn't really in place (no function to determine the horizontal extents of the outliner).
Aligorith
artisanicview
Post by artisanicview »
Auralis wrote:Not only a horizontal scrol, but a better vertical scroll as well.
Really? You know how to scrol the text window in both horizontally and vertically directions? Simply Press the scrool mouse butoon and voala! You can scrol werry easy in what direction you want.
I hope the same function will be implemented in the Outliner windows. Also the OOPS schematic from the same outliner window have this scrooling function. So I think will not be so hard to implement this function.
stiv
Post by stiv »
Scroll bars are for girly-men.
Use the middle mouse button.
fobsta
Post by fobsta »
There were originally more features planned for the outliner.
http://www.blender.org/cms/Outliner.437.0.html
http://mke3.net/blender/interface/layout/outliner/
Coders just need reminding of them :wink:
Auralis
Post by Auralis »
artisanicview wrote: Really? You know how to scrol the text window in both horizontally and vertically directions? Simply Press the scrool mouse butoon and voala! You can scrol werry easy in what direction you want.
I know that, however it its subobtimal if you have say 1000+ objects in the outliner.
aligorith
Post by aligorith »
Now that I've got a working build-environment, I can start experimenting with how to add this.
In my latest attempt, I've got it working to some degree ;) However, there are some problems which I'm still trying to investigate:
- After creating a new outliner space, the outliner contents are all pushed off to the right, seemingly to the size that the space was when created.
Hints anyone?
- Horizontal bars do not draw infinite-ly yet
the line in question is
Code: Select all
glRecti(0, ystart, (int)soops->v2d.mask.xmax, ystart+OL_H);
I know that the values I want to change are argument 1 and 3. But what do I put there instead?
- on old blend files, existing outliner views don't want to support these features (out of scope of my work, but might look into it. I suspect it's got to do with the way spaces function - once the space has been init-ted, it stays that way, and passes its settings to whatever might live there next.
I probably should read up on this, but what is v2d->tot. I know that tot is some kind of struct/variable attached that is part of the v2d variable (or whatever the term is)
Aligorith
aligorith
Post by aligorith »
Well, I seem to have solved point 2 already! by doing:
Code: Select all
glRecti((int)soops->v2d.cur.xmin, ystart, (int)soops->v2d.cur.xmax, ystart+OL_H);
it seems to work ok. If I shouldn't be doing that, I would like to know.
Tomorrow, I will tackle number 1. I hope it might only involve changing a few settings and then bang. It's fixed.
More tomorrow,
Aligorith
ElBarto
Post by ElBarto »
There are a lot of features missing in the outliner and the interface could adopt the new interface of the node editor:
Uniform GUI and workflow for the Oops
http://www.neeneenee.de/blender/features/#29
Uniform workflow for the Outliner
http://www.neeneenee.de/blender/features/#31
Karamba!
Bart.
http://www.area42.de/
Blender Feature Proposal:
aligorith
Post by aligorith »
Yay!
I've finally got this working as it should! There are only two minor annoyances, but these are a result of other parts of blender and not my code.
Unfortunately, this is too late for 2.42, as it's already CVS freeze mode. However, after cleaning this up and checking if anything else needs to be done, I will submit a patch to the patch tracker tomorrow.
Aligorith
aligorith
Post by aligorith »
I submitted the patch yesterday. Now, time to bug some people with commit rights to commit it...
Aligorith
