Bcon2006 session: What i wish to have in Blender
ElBarto
Post by ElBarto » Tue Oct 24, 2006 12:47 pm
in the "What i wish to have in Blender" session
Roland and Bassam wished there where named layers in Blender.
I thought about it and made some screens:
Layer name and color (for wireframe mode in 3d view) setup in the draw panel:
Layer names when moving objects from one layer to another:
Layer names in the headerbar of the 3d view:
I didn't find a good solution for the Armature layer yet (Bassam's wish).
Not all file formats support multimaterial per mesh so it would be cool at add an entry to the Seperate menu called "By Material Indices":
Karamba!
Bart.
Karamba!
Bart.
http://www.area42.de/
Blender Feature Proposal:
http://www.neeneenee.de/blender/features/
joeri
Post by joeri » Tue Oct 24, 2006 4:08 pm
I'm all for the material split, actualy I think it's then a vertex group split (very doable with the select by vertex group-> separate) , but anyway...
Ton stated it could easaly be done in the exporter to the troublesome fileformat.
joeri
Post by joeri » Tue Oct 24, 2006 4:37 pm
Btw... I thought the session got a bit out of hand when blender features where suggested using blender as suppost to the excellent demos of what other packages have as great features.
I thought most demos where about previsualizing what is going to happen and post action visual alteration.
- Snapping by showing in wire or with icons where the moving object will get snapped to.
- Aligning
- Altering values after a tool is used:
for example add icosphere and then have a numslide to alter subdivs and see what number does what.
As showed by matt.
Actualy I'm not to sure there should be an OK. Hitting a hotkey should automaticly make this action go OK.
This should also work for select, delete, etc. etc.
ElBarto
Post by ElBarto » Wed Oct 25, 2006 11:20 am
Hi Joeri,
may we need both "By VertexGroups" and "By Material Indices". The Radiosity feature creates Material Indices but not new vertex groups. May some people want to split in vertex groups.
I talked to Roland Hollman which shows the snapping in MicroStation at the BConf and we developed a workflow for snapping.
I will visulize that soon.
Karamba!
Bart.
Ammusionist
Feature Request
Post by Ammusionist » Thu Oct 26, 2006 5:09 am
Can we have Random (0 - 100% & Seed) values in the Array Modifier?
Would produce a seperate multiplyer for each array parameter
It's be fantastic to produce arrays with some jitter.
Afterthought: You should be able to make it even or cumulative as well
(Even - each iteration is calculated from original then randomly offset)
(Cumulative - each iteration is calculated from previous then randomly offset)
Wish I could remember 1/2 my C and C++ classes from Tech, then I'd have a go myself.
matt_e
Post by matt_e » Thu Oct 26, 2006 8:27 am
Joeri, thanks for mocking up that image, that's a good description of what I was trying to talk about. FYI, the demonstration video of the same sort of workflow concept from Modo that I showed is here: http://content.luxology.com/modo/201/vi ... ension.mov
cheers
joeri
Post by joeri » Thu Oct 26, 2006 2:49 pm
I think it's important that the sliders and numbuts need to be non-blocking. So I can keep holding my LMB and still see what changes will happen.
For the meantime it might be possible to create a hack that just does an undo and then a redo with new values.
ElBarto
Post by ElBarto » Mon Nov 06, 2006 7:14 pm
I'd like to have a "Neg" button for inverting the blend mode. Often i'd like to switch HOR and Zen color which is at the moment very painfull.
Or a "NegMode" and "Neg" button, "NegMode" negates the blending mode by switching HOR and ZEN color and "Neg" inverts the colors.
Karamba!
Bart.
jack
Layer names, sets, selection, locking proposal
Post by jack » Thu Nov 16, 2006 11:14 am
a while ago I thought about something like a layer manager and created some screenshots of what it could look like. Perhaps any programmer gets inspired.
Check it out here: http://www.jackbox.woidwideweb.de/tmp/l ... /index.php
Greetings!
