3DS Exporter Prefixes Object Names
xptical
Post by xptical »
I'm doing models for a program called RealFlight. It's a RC model simulator that imports .KEX models.
They have, on the site, a 3ds2kex converter.
The problem is that in order to work properly, the objects have to have specific names.
~CS_Wing must be connected to ~CS_Fuselage. ~CS_Aileron must be connected via a pivot to ~CS_Wing.
I hope that makes sense.
Currently, blender's models must be opened in another program to name the parts.
The reason is that the 3ds Export script prefixes the object names with a "0".
Here's an example:
File >> New >> Erase All
F5 >> Name Object as "~CS_Box"
File >> Export >> 3DS
Now, open the file with 3D Studio or Deep Exploration. Or even re-open it with Blender.
The object will now be named 0~CS_Box.
How can I avoid this?
reD_Fox
Post by reD_Fox »
Hello,
In order to correct this "problem," you need to locate and open the "3ds_export.py" script file in a text editor (I'm assuming you are still using Blender 2.43). Line 973 should be the following:
object_chunk.add_variable("name", _3ds_string(str(i) + ob.name))
Change this to
object_chunk.add_variable("name", _3ds_string(ob.name))
From what I can tell (I'm not familiar with the script, .3ds files, or anything related to .3ds files), this should correct the problem. This is assuming, of course, that a leading number is not necessary for the .3ds format. In other words, I can't guarantee the results, so let me know if there are further problems and I'll see if I can get someone who knows more than I do to take a look at the issue.
Levi
A three-legged stool never wobbles.
xptical
Post by xptical »
Thanks. That worked like a champ.
Do you know why it was doing it that way to begin with?
reD_Fox
Post by reD_Fox »
Yeah, it was to prevent duplicate names. The current CVS (and the upcoming Blender 2.44) will have this issue resolved.
Glad to be of assitance!
Levi
