Need help to write an export plugin that does the following:
Desperado
Post by Desperado » Mon Jun 04, 2007 2:51 pm
Hello folks,
for a research project, I need to write an export plugin that does the following:
Let's say, the whole scene consists of one mesh who's faces are all quadrilaterals and who form a rectangular grid.
Then the export script should walk through all the quadrilaterals and output it's vertices, but it shoud ALSO output the vertices of the eight faces adjacent to the current surface.
Is it possible in Blender Python to fetch adjacent vertices to an existing one?
Thank you in advance
reD_Fox
Post by reD_Fox » Mon Jun 04, 2007 6:41 pm
Hello,
Yes it is possible, but not directly. You need to loop through all the faces, store adjacency data, and then loop through them again using this data to accomplish what you described in your post.
If you need further direction I can provide some more helps, but I would also recommend you check out the BlenderArtists.org forum since it is a bit more frequented:
http://blenderartists.org/forum/forumdisplay.php?f=11
Levi
A three-legged stool never wobbles.
