I did simple script to increase sequencer functionality.
Idea is simple:
You select some _hard_ strip like scene or glow or even transitions which slowdowns playback and push rendering->sequencer preredner
script renders region where this hard strip located and puts rendered sequence over all strips. After it sequencer should play this sequence instead of rendering its source.
OK. But I have one problem.
BSE evaluates strips in _CRAZY_ order and I can't overlay part of timeline.
Please make some predictable order for strip rendering like render topmost strip.
This is cript listing:
sequencer_prerender.py
Code: Select all
#!BPY
Name: 'Sequencer prerenderer'
Blender: 245
Group: 'Render'
Tooltip: 'renders selected strip to plain png sequence'
# Author: IL'dar AKHmetgaleev aka AkhIL
# e-mail: akhilman at gmail dot com
# web: http://akhil.nm.ru
# This code is licensed under
# Creative Commons Attribution 3.0 Unported License
# http://creativecommons.org/licenses/by/3.0/
from Blender import *
scn = Scene.GetCurrent()
seq = scn.sequence
active_strip = seq.active
if not active_strip:
print 'select one strip'
raise Exception
start = active_strip.start \
+ active_strip.startOffset - active_strip.startStill
end = active_strip.start + active_strip.length - 1 \
- active_strip.endOffset + active_strip.endStill
start = max(start,1)
end = max(end,1)
context = scn.getRenderingContext()
old_start = context.startFrame()
old_end = context.endFrame()
old_renderpath = context.renderPath
old_extensions = context.extensions
old_imagetype = context.imageType
context.startFrame(start)
context.endFrame(end)
context.renderPath = '//tmp/seq.prerender/'
context.extensions = True
context.renderAnim()
channel = max( map( lambda x: x.channel, seq ) ) + 1
data = ( context.renderPath, map(lambda x: '%04d.png'%x, range(start,end+1)))
strip = seq.new(data,start,channel)
strip.name = "prerender"
context.startFrame(old_start)
context.endFrame(old_end)
context.renderPath = old_renderpath
context.extensions = old_extensions
context.imageType = old_imagetype
Window.RedrawAll()
