Server TCP Python
Tamaya
Server TCP Python
Post by Tamaya »
I've got a problem with a TCP Server script... I just want to receive x y coordinates in order to make my 3D objects moves.
I've made it on a thread, but my client can't connect to it. It seems to be a problem on the socket creation:
Here is the code of the script:
from socket import *
import threading
import time
myHost = "localhost"
myPort = 4242
print("Creating socket ...")
s = socket(AF_INET, SOCK_STREAM)
print("Binding socket ...")
s.bind((myHost, myPort))
print("Now listening ...")
s.listen(1)
class myThread(threading.Thread):
    def __init__(self, name=None):
        threading.Thread.__init__(self, target=self.run, name=name, args=())
        self.run()
    def run(self):
		print("Thread ready")
		while 1:
			connection, address = s.accept()
			print("Connection accepted ...")
			while 1:
				print("recv")
				data = connection.recv(1024)
				print ("data: ")
				print data
				if not data:
					print("stop connection")
					connection.close()
					break
print("Threading ...")
t = myThread("server")
print("Script ended")
Tamaya
robothespian
Re: Server TCP Python
Post by robothespian »
Does your socket even connect???
Have you tried a simple server + client program to test it - there is one here if not:
http://www.python.org/doc/2.2.3/lib/socket-example.html
If your socket connects and you get "Thread ready" - compiling your code on my machine gets this far, you may be suffering from the socket blocking on the recv call - I am not sure if the socket.accept call blocks, but that may be the same too.
I have set up a socket to allow something else to control my Blender model and here is the stripped out version of my code (you will need to change SOCK_DGRAM, to SOCK_STREAM).
If you set this up, you may "lock up" the Blender interface, so you may have to add an "Exit" button handler - look in this tutorial on how to make a GUI programme and exit your script nicely. (You should use an external Quit / Button handler to set finished = True or similar):
http://feeblemind.tuxfamily.org/dotclea ... -02-en.pdf
I have got to the stage where I can receive data and move bones around, but something - probably threading - seems to be crashing Blender, so watch out...
Here is rough code - check carefully and make a client to talk to it for testing or something.
# UDP server example!!
import socket, time, struct, sys
server_socket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
#We allow the call to recvfrom to timeout after 1 second...
server_socket.settimeout(1)
server_socket.bind(("", 7771))
finished = False
while False == finished:
    try:
        data, address = server_socket.recvfrom(256)
        print "data ", data
        #This does not work very well, so you might want to comment it out.
        if True == Blender.Window.TestBreak():
            finished = True
            print "User pressed Escape"
    except socket.error, msg:
       print "socket timeout %s " % (msg)
print "Finished"
Tamaya
Post by Tamaya »
Sorry for be late...
I've made a UDP server, with a try bloc...
Init:
GameLogic.sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
GameLogic.sock.bind(("localhost", 4242))
GameLogic.sock.setblocking(0)
On all frames:
data = "empty_"
try:
	data, addr = GameLogic.sock.recvfrom(3000)
except:
	pass
if (data != "empty_"):
That's work good; If there is no data, the except is called, and so it pass on it and I have no warning on the console.
I will try the GUI too, but my server works good now and I have many work on other parts of my project!
Thanks for your help !!
Tamaya
robothespian
Game Engine vs Blender
Noticed you are doing a similar thing to what we want.
Do you receive a lot of data through the socket?
We want to animate a robot with data for each of it's armature / bone positions in real time with socket data, but it is slow and Blender "locks up".
Do you use the Game Engine to do this?
I tried Threading, but Blender crashed when it received lots of data - if I remove the thread and just do the socket in a script loop it works, but the interface is "locked up" if there is no incoming data. I can press the ESC key when data is incoming and the script exits, but otherwise it does not...
Do you have any ideas?
Thanks
trickiricki
Re: Game Engine vs Blender
Post by trickiricki »
robothespian wrote:Hi,
Thanks
sorry for resurecting this old thread, but i have the same problem with a locked blender while using threads... how did u managed the problem robot?
my question can be found here:
http://blenderartists.org/forum/showthr ... ost1603276
Post by stiv »
You need to do non-blocking I/O.
Due to the Global Interpreter Lock (GIL), Python threads execute in an interleaved one at a time fashion. Anytime a thread blocks, the whole mess stalls.
trickiricki
stiv wrote:You need to do non-blocking I/O.
thanks for your answer stiv! i understand what you mean, but can't solve the problem.
here is a short test passage from the code:
import threading
class BlenderThread(threading.Thread):
	def __init__(self):
		threading.Thread.__init__(self)
	def run(self):
		import Blender
		import time
		def add_mesh_to_scene(mesh, loc, name):
			obj = Blender.Object.New('Mesh',name)
			obj.link(mesh)
			myScene = Blender.Scene.GetCurrent()
			myScene.link(obj)
			obj.setLocation(*loc)
			print "cube drawn to scene"
		def create_cube():
			myMesh = Blender.Mesh.Primitives.Cube(2)
			add_mesh_to_scene(myMesh, [0,0,0], 'Cube')
		print "THREAD: started"
		print "THREAD: sleep 5sec"
		time.sleep(5)
		print "THREAD: wake up"
		create_cube()
		Blender.Draw.Draw()
		Blender.Window.RedrawAll()
		Blender.Window.Redraw()
		Blender.Redraw()
		Blender.Scene.GetCurrent().update()
		time.sleep(5)
		print "THREAD: finished"
print "SCRIPT: started"
thread = BlenderThread()
#my_threads = []
#my_threads.append(thread)
thread.start()
#print "SCRIPT: collect thread"
#for t in my_threads:
#	t.join()
print "SCRIPT: finished"
even if i remove the whole remote stuff from my code i'm running in two diffrent problems:
1) my blender window won't get redrawn, when i don't give focus to it or moving my mouse in the focused window
2) i can't operate in blender while a thread is running and the (main) script waits for the thread to end (activate lines 47, 48 and 53, 54)
i think there is an issue with blenders window manager when you don't finish threads correctly with the join-method, blender and the thread don't know each other and interact indirect with each other...
quinput
Post by quinput »
I try a similar thing. I would like to to use blender to display data from a external simulation.
The problem seems to be that after the regular script has finished and only the threads are running that we have no longer access to bpy.ops.*
But bpy.data is still accessible. So I can set a custom property. And this property can be read inside of BGE. No ideal solution, but this could work.
Better would be if we could inject a cmd in the main event loop if we run a background python thread.
ldo
Post by ldo »
Generally you should avoid using threading within an addon to a host application, unless the host application explicitly supports it. I don’t recall any mention anywhere that Blender supports threads within addon scripts. So don’t do it.
quinput
Post by quinput »
ldo wrote:Generally you should avoid using threading within an addon to a host application, unless the host application explicitly supports it. I don’t recall any mention anywhere that Blender supports threads within addon scripts. So don’t do it.
I have used threads long enough that know if I access blender internal stuff direct in a thread that this is a recipe of a disaster. I would need a network interface in the core C part to inject commands in a proper way in main control loop.
But I have seen after some experiments that you can modify the basic rotation and position attributes of objects without much harm. I start inside a script a http server and finish the script. Inside of the http requests I can set the basic attributes.
The source code is here: http://p.quinput.eu/qwiki/Wiki.jsp?page ... te_control
I think this approach could work good enough for some quick and dirty simulation visualization.
