AttributeError: 'NoneType' object has no attribute 'bones'
syco
Post by syco »
hi, i'm not new to blender but I can not really understand why this error in a code copied from the api.
the code is:
Code: Select all
from Blender import *
def test_arm():
	scn = Scene.GetCurrent()
	arm_ob = scn.objects.active
	if not arm_ob or arm_ob.type != "Armature":
		Draw.PupMenu('not an armature object')
		return
	# Deselect all
	for ob in scn.objects:
		if ob != arm_ob:
			ob.sel = 0
	arm_mat = arm_ob.matrixWorld
	arm_data = arm_ob.getData()
	bones= arm_data.bones.values()
	for bone in bones:
		bone_mat = bone.matrix['ARMATURESPACE']
		bone_mat_world = bone_mat*arm_mat
		ob_empty = scn.objects.new('Empty')
		ob_empty.setMatrix(bone_mat_world)
test_arm()
i copied it from these page: http://www.blender.org/documentation/24 ... odule.html
the error is:
Code: Select all
Blender Game Engine Started
Oops - can't get the armature weakref list
Python script error from controller "cont2#CONTR#3":
  File "braccio.py", line 5, in <module>
dfelinto
Post by dfelinto »
You tried to run it in the Blender Game Engine. However the script example you are looking for is to be used in Blender itself.
So instead of launch BGE (pressing P) go to the Text Editor window and press ALT+P (or RMB+Run Script)
Rio de Janeiro - Brasil
http://blenderecia.orgfree.com
