Blender.Redraw() method no more available in 2.51 API?
mb
Post by mb »
I am upgrading my old python scripts from Blender 2.49 API to 2.5 API.
In many of them I make use of the Blender.Redraw() method, which is very handy, among others, for making animations directly in the editor environment, rather than in the gamelogic.
Unfortunately I've not found any equivalent method in Blender 2.5, yet.
I would expect something like: bpy.ops.window.redraw(), or similar, to replace the old sintax.
Thanks.
mb
zaphodile
Post by zaphodile »
Doesn't anyone know? I'm wondering the same thing.
SL1200
Post by SL1200 »
Hi, I was looking into this function just now and saw your post.
bpy.ops.wm.redraw_timer()
Simple redraw timer to test the speed of updating the interface
Hope this is what you need.
Everyone I meet is my superior, and being that, they can teach me something new.
jonathan_dowdall
Post by jonathan_dowdall »
Each time the screen needs to be updated use the following:
bpy.ops.render.render()
bpy.ops.wm.redraw_timer(type='DRAW_WIN_SWAP', iterations=1)
mb
Post by mb »
jonathan_dowdall wrote:Each time the screen needs to be updated use the following:
Thank you: it works but compared to the previous redraw method it seems very slow.
To move the cube 4 blender units along the z-axis I tried this:
import bpy
from mathutils import Vector
Obj=bpy.data.objects["Cube"]
for p in [1,2,3,4]:
    Obj.location = Obj.location + Vector((0,0,1))
Are there any parameters that can be adjusted to control the refreshing rate?
rylangrayston
Post by rylangrayston »
Is rendering the scene so an easy way to change the speed is simply to
lower the resolution of the render to 1 percent.
By doing that I got my script to redraw the screen about 10 times faster
rylangrayston
Oh and another way to make it go faster is to the hold esc key with your mouse in the 3d window pain... this way is nice because if your render settings are hi then you can change between two speeds while your script is running!
mb
Post by mb »
rylangrayston wrote:Oh and another way to make it go faster...
Thank you for both of your suggestions.
However I have finally abandoned the idea of making animations in the editor environment: I converted my scripts to work in the game engine and now I'm happy with that.
mb
