Report problems with the new Python API here please!
- Location: Somewhere below the rivers in Holland (but not Limburg)
I would like to collect all problems, bugs, inconsistencies and small changes in this topic. When you have found a problem, please first check if somebody else has already reported it. If the problem you've found is not posted yet, please give a complete report on how to reproduce it - if applicable with a few lines of Python code.
Do not ask for any new modules to be added for the 2.28 release. After 2.28 is released, new modules can be added.
Thank you for testing.
With regards,
Michel
With regards,
Michel
Re: Report problems with the new Python API here please!
OK.Michel wrote:Hi,
I would like to collect all problems, bugs, inconsistencies and small changes in this topic. ..
in module BLender.Object
Code: Select all
import Blender
OBJLIST=Blender.Object.Get()
for o in OBJLIST:
print o.name,o.Layer,
Using a clean Global Dictionary.
Run Python script "Text" ...
File "Text", line 4, in ?
AttributeError: 'str' object has no attribute 'name'
Zoo-3D.Blender, Ze French-Speaking Community SKB My french book about Blender.
I notice that the object names are now being reported differently to version 2.23.
For instance I have a tyre of radius 3.5 with an anti-clockwise forward rotation called Tyre01-3.5
my script extracts the data using the .name. so:
mTyre = Blender.link
rad = eval(mTyre.name[7:])
dir=eval(mTyre.name[6] + "1")
Under version 2.23 this works fine, but under this test version it doesn't. Adding the line:
print mTyre.name
shows that the returned name is now OBTyre01-3.5 instead of Tyre01-3.5.
I know it's a minor issue, solved by adding 2 to the substring arguments, but it's one people need to be aware of. I assume this is a permanent feature of the code and not just some test diagnostic s
print mTyre.name
Whoops, this is a stupid error. This will be fixed. Thanks!gowen wrote:Under version 2.23 this works fine, but under this test version it doesn't. Adding the line:
print mTyre.name
I know it's a minor issue, solved by adding 2 to the substring arguments, but it's one people need to be aware of. I assume this is a permanent feature of the code and not just some test diagnostics
With regards,
Michel
I will look into this! Thank you.jms wrote: in module BLender.Objectreturn this:Code: Select all
import Blender OBJLIST=Blender.Object.Get() for o in OBJLIST: print o.name,o.Layer,
With regards,
Michel
This seems to work:Michel wrote:I will look into this! Thank you.jms wrote: in module BLender.Objectreturn this:Code: Select all
With regards,
Michel
Code: Select all
import Blender
O=Blender.Object.Get()
Olist=[]
for o in O:
print type(o)
Olist.append(Blender.Object.Get(o))
print str(Olist), type(Olist[0])
if str() is not used.
Can't seem to get name in PutRaw to return anything except None, as in:-
Code: Select all
import Blender
from Blender.NMesh import Col
from Blender.Draw import *
import string
meshname="Cube"
me= Blender.NMesh.GetRaw(meshname)
i = 1
for f in me.faces:
new = Blender.NMesh.GetRaw()
new.verts = f.v
f.mat = 0
new.faces = [f]
ob=Blender.NMesh.PutRaw(new)
ob.name="Cube" + "." + string.zfill(`i`, 3)
print ob.name
i = i + 1
print i ,"pieces"
print "-------------------------------"
Blender.Redraw()
I have a set of python scripts inside blender file, example: main.py, first.py
This files are not in my disk only in the blender file.
In the main.py I just to import the first.py with:
import first
or
from first import *
With the old python It works OK, but now an error message appears
"ImportError: No module named first"
import first
or
from first import *
Blender.Lamp.Get()
Win32 = > Win98:
crash...
not.
Code: Select all
import Blender
L=Blender.Lamp.Get()
print L
Code: Select all
import Blender
print str(L)
_Blender ?
Code: Select all
import _Blender
File "Text.001", line 1, in ?
ImportError: No module named _Blender
world module
a Blender.World.getCurrent()/setCurrent() functions could be useful.
- Contact:
This doesn't work:
Fails with
Also, it appears that materials are now linked to objects (before it was linked with object data). In the settings window, I have "Material linked to" set to ObData as well.
Code: Select all
objs = Blender.Object.Get()
#objs returns ['Plane', 'Camera', etc...]
for obj in objs:
#obj returns Plane (no quotes)
name = obj.getData()
Code: Select all
AttributeError: 'str' object has no attribute 'getData()'
-ray_theray
Problem with matrix too:
Code: Select all
import Blender
L=Blender.Object.Get('Lamp.001')
print L.getMatrix()
2.27 new-py
((0.0, 0.0, 0.0, 0.0),
(0.0, 0.0, 0.0014120666310191154, 0.0),
(0.0, 0.0, 0.0, 0.008771928958594799))
2.27 normal
((1.0, 0.0, 0.0, 0.0),
(0.0, -4.3711388286737929e-008, 1.0, 0.0),
(0.0, -1.0, -4.3711388286737929e-008, 0.0),
(-0.25819849967956543, -7.2443208694458008, 5.5631
518363952637, 1.0))
