Use native python libraries on 2.54 doesn't work?
FidoX
Post by FidoX »
This works to somebody on 2.54?
Code: Select all
import bpy
import os
class TestPanel(bpy.types.Panel):
	bl_space_type = "PROPERTIES"
	bl_region_type = "WINDOW"
	bl_context = "render"
	bl_label = "Test import os"
	def draw(self, context):
		layout = self.layout
		scene = context.scene
		print(os)
		row = layout.row(align=True)
		if(os == None):
			row.label("os not imported")
bpy.types.unregister(TestPanel)
bpy.types.register(TestPanel)
dfelinto
Post by dfelinto »
this will not work. There is no longer need to register and unregister your operators. The only thing you need to register now are properties stored in your blender objects (e.g. scene.my_custom_property). Your sample code rewritten for current API would be:
Code: Select all
import bpy
import os
      print(os)
      if(os == None):
      else:
         row.label("os imported")
def register():
    pass
def unregister():
    pass
if __name__ == "__main__":
    pass
Rio de Janeiro - Brasil
http://blenderecia.orgfree.com
