Bake to texture in python
Posted: Mon Jun 20, 2011 7:12 pm
by karljj1
Hello,
I am trying to bake all the textures of a model into a single texture. I have managed to do this manually and am now trying to write a script to do this. However some of the blender operations do not show me the python calls so i am a little stuck. Here is what i do so far:
	def CreateAtlas() :
		bpy.ops.mesh.uv_texture_add()
		bpy.ops.object.editmode_toggle()
		bpy.ops.uv.smart_project( angle_limit = 66, island_margin = 0 )
		img = bpy.ops.image.new( name='Atlas', width = 1024, height = 1024 )
		#How do i assign the image to the uvs???
		bpy.context.scene.render.bake_type = 'TEXTURE' # Set to bake texures only
		bpy.ops.object.bake_image()
After i uv project i need to change the image that is used to a new image however i do not know the python command to do this. It is the ittle icon of an image with a drop down list of images that lets me select the new image. Any suggestions? When i hover my mouse over it the tool tip is 'Browse Images to be linkled', it does not show the python command in the tooltip :(
Thanks
Posted: Wed Dec 21, 2011 8:15 pm
by underdoeg
I'm struggling with the exact same problem.
Did you ever get it working?
So far I have
bpy.data.screens['UV Editing'].areas[1].spaces[0].image = image
But I am not entirely sure if this is a good way to go?
Posted: Thu May 30, 2013 4:02 pm
by Bhil
underdoeg wrote:I'm struggling with the exact same problem.
So far I have
Blender 2.6 example:
# get first selected object (only as an example)
my_obj = bpy.context.selected_objects[0]
# create new image
uv_image = bpy.ops.image.new (
    name   = "empty",
    width  = 4096,
    height = 4096,
    color  = (1.0, 1.0, 1.0, 1.0),
    alpha  = False,
# apply new image to uv
my_obj.data.uv_textures[0].data[0].image = uv_image
Be sure to have a uv map applied to your object. Otherwise the uv_textures[0] will not be available. You can insert any image for uv_image.
See here:
http://www.blender.org/documentation/bl ... image.open
and here:
http://www.blender.org/documentation/bl ... .image.new[/code]
Posted: Thu May 30, 2013 5:37 pm
by CoDEmanX
this is a two years old thread...
well, image assignment should actually be done per loop like
img = bpy.data.images[0]
for uvface in bpy.context.object.data.uv_textures.active.data:
    uvface.image = img
