updating a curve object
Haunt_House
Post by Haunt_House »
Hi
is there a way to update a curve object when I changed it through python?
Of course I could use tab tab, but this is not too handy within rendering an animation.
thanks in advance
Haunt_House
Post by stiv »
At the moment, this behavior ( or non-behaviour! ) is a Great Mystery. Even as we speak, research is taking place at a Secret Laboratory.
Rest assured that this problem *will* be solved.
Haunt_House
thanks in advance :o
If I only knew more about forces and kinetics. then I would do the cables meshbased and iterative.
lukas
Post by lukas »
stiv wrote:Rest assured that this problem *will* be solved.
Glad to hear that. I'm stuck with the same prob.
Is there a way of getting notified once this is solved (even if it is in cvs only)?
Oh, btw, there was another funny thing about the curves in phyton.
Methods for retrieving the number of points/curves are missing. I checked out cvs yesterday and saw that the actual code was there, but the respective methods weren't added to the method table.
I inserted them just out of curiosity (and since i needed them :D) and it seems to work as expected. Is there any reason for them not beeing enabled yet?
Other thing: What about adding/removing control points to a curve? Did i miss something, or is it just not implemented yet?
tia
Post by stiv »
lukas wrote: Glad to hear that. I'm stuck with the same prob.
I think I have a handle on it. Essentially, after we have updated the Curve datablock, we need to chase down all the Objects linked to it and have them update their display lists. I'll let you know when I'm sure.
The methods were implemented. Either the .h file didn't get updated or didn't get checked in. They *should* work. Let me know if they don't.
Ahhh, the evolving python interface. I have coded up some methods. We were discussing exactly what the interface should look like. Plus that previously mentioned problem with updating display lists.
Currently, there is a code freeze for the 2.28x release. The next cvs checkin should have *all* the goodies we've talked about.[
lukas
Post by lukas »
stiv wrote:I think I have a handle on it. Essentially, after we have updated the Curve datablock, we need to chase down all the Objects linked to it and have them update their display lists. I'll let you know when I'm sure.
Great! Thanks.
As far as i can tell: They work. I have a running py scriipt, that uses them w/o probs.
i am looking forward to it.
btw, i don't know who was responsible for the automake setup, just wanted to give big respect: Blender was the first "bigger" project in years , that i was able to check out and build out of the box (bootstrap,configure,make). No tricks, no tweaks, no glitches. It simply worked. Amazing! :D
Thx again.
