Get Game Property of an Object
zoltinho
Post by zoltinho »
Hi all!
On object A I have a property sensor which triggers a script. I need this script to be triggered once the scene is completely loaded and ready for user interaction, therefore I decided to make an 'always' sensor on the game camera, which would set the property, thus triggering the sensor on object A.
My problem is that I can't find a way to access any of the game properties defined for object A from the game camera, so I can't trigger the property sensor.
If object A was the owner of the script that changes the property, I could do
Code: Select all
cont = bge.logic.getCurrentController()
own = cont.owner
own['property'] = 1
But that's not the case. I tried fetching object A using
Code: Select all
bpy.data.objects['A']
but this does not give me access to its game properties.
Is there another way to access object A's game properties?
mb
Post by mb »
Try to access the object by its name, rather than as the "owner" of the controller, i.e.:
Code: Select all
obj = bge.logic.getCurrentScene().objects['ObjectA']
obj['property'] = 1
mb
