world/local Position for 2 objects having same parent
webmyster
Post by webmyster »
As I understand, the worldPosition of an object is the combination of the localPosition of the object and the worldPosition of its parent. Right ?
I'm assuming that its worldOrientation and its localOrientation is set to identity (ie : no rotation). Moreover, there is no other intermediate object (direct relation).
Thus, if an object have its local position set to (0.0, 0.0, 0.0), then, its worldPosition is the same than the one of its parent. Right ?
Given two objects attached to the same parent, if both localPosition are set to (0.0, 0.0, 0.0), they should have the same worldPosition. Right ?
I have a scene with a camera and a gun both defined as son of a "vehicle" object. Each one has its localPosition equals to (0.0, 0.0, 0.0). But both have different worldPosition that is not the same than parent's one.
Did I miss a reference frame in the composition ?
mb
Re: world/local Position for 2 objects having same parent
Post by mb »
webmyster wrote:Hi,
I tried to reproduce the situation but everything works as expected.
Could you post a simplified copy of your file?
