armature_add() function positioning error
wretch1958
Post by wretch1958 » Sun Apr 29, 2012 8:11 am
Code: Select all
vec1 = [0, 0, 0]
bpy.ops.object.armature_add(view_align=False, enter_editmode=False, location=vec1, rotation=(0, 0, 0), layers=(True, False, False, False, True, False, False, False, False, False, False, False, False, False, False, False, False, False, False, False))
vec1 = [0, 0, 5]
Is there a bug with the armature add function, when the position vector is anything other than 0,0,0 ???? In the above code, the first armature command works fine but the second one does not put the armature above the first one along the z axis. In fact, it appears to reset the origin or something?
CoDEmanX
Post by CoDEmanX » Sun Apr 29, 2012 1:39 pm
dunno if this is a bug or a feature
It creates the Armature object at the given coordiante, but the initial bone's head gets placed at 3D cursor position, tail 1 unit in z-direction above 3d cursor.
Code: Select all
vec1 = (0, 0, 0)
bpy.context.scene.cursor_location = vec1
vec2 = (0, 0, 5)
bpy.context.scene.cursor_location = vec2
bpy.ops.object.armature_add(view_align=False, enter_editmode=False, location=vec2, rotation=(0, 0, 0), layers=(True, False, False, False, True, False, False, False, False, False, False, False, False, False, False, False, False, False, False, False))
wretch1958
Post by wretch1958 » Fri May 04, 2012 9:37 am
Thanks "codemanx". !!!
ldo
Post by ldo » Mon May 07, 2012 1:09 pm
I hate seeing repetitive code. To generate the layers tuple, how about
Code: Select all
(True,) + 19 * (False,)
or even
Code: Select all
tuple( i == 0 for i in range(0, 20))
where the 0 can be changed to any other layer number to correctly generate a tuple that has a single True element at the right index.
If you want the object to be in more than one layer, say it needs to go on layers 1, 3 and 5, then do
Code: Select all
tuple( i in (1, 3, 5) for i in range(0, 20))
Isn’t that so much easier to write?
