getting ipocurve name for action quats
club_soda
Post by club_soda »
Gents,
I'm writing some exporter code to export skeleton animation, and I decided to be smart and grab the ipo curves by name instead of index in the ipo. However, it seems that the quaternion ipos Quat{X/Y/Z/W} fail when I attempt to use ipocurve.getName() on them.
Since quat ipocurves are ipocurves with codes 25-28, it seems I can just add them to the name array in the function IpoCurve_getName() ( in python/api2_2x/ipocurve.c). But I'm not sure it is this simple. It seems there are object ipocurvess and action ipocurves; do I need to distinguish between them to figure out what ipocurve name to return? Is there anything else going on that will screw up this simple fix?
Thanks,
Gary
der_ton
Post by der_ton »
I´m having the same problem.
Gary, is there a workaround for Blender2.31? You provided me with some code that worked in 2.28 (a while back on elysiun.com), but it doesn´t work in 2.31 anymore...
Thanks,
Tom
reimpell
Ipo flaws
Post by reimpell »
der_ton wrote:is there a workaround for Blender2.31?
You can put your old code into a
Code: Select all
try:
  # insert old code
except TypeError:
  # insert code for blender 2.32
block and try to guess Ipo names depending on getNcurves().
Regards,
Michael
der_ton
Post by der_ton »
Yep that´s what I´m doing...
but still I have encountered problems with the "guessing the name of the curve from its index number" method:
http://www.blender.org/modules.php?op=m ... pic&t=2911
breakin
Post by breakin »
I've submitted a patch for this that hopefully gets accepted into the cvs-version of blender later today. It returns names for action-ipos as well as object-ipos. Unless I've missed something obvious it should be there.
