Problem rendering - can't get camera active (python script)
werty_TSS
Post by werty_TSS » Thu Jan 10, 2013 11:48 am
I've got a python script to post treat a series of X3D files. I import one after another, treat the file and export as PNG. Problem is when I want to render the scene, it says "no camera" which is not true, there is a camera. My problem is that I can't script it to have it set my camera as active so it can render.
here s the script. It's not pretty (yet), i'm new with that...
At the begining, i set up the bathymetry of the region i want to plot. Then, I keep the bathymetry and change the chemical file for each time step, which i save.
#-- Place lights
bpy.ops.object.lamp_add(type = 'HEMI', view_align = False, location=(3,15,3), rotation=(0,0,0))
bpy.ops.transform.rotate(value=(-3.1415/2,),axis=(1,0,0), constraint_axis=(True,True,True), constraint_orientation='GLOBAL')
#-- Place camera
bpy.ops.object.camera_add(view_align = True, enter_editmode=False, location = (3,18,0), rotation= (0,0,0))    # !!! CHECK GLOBAL/LOCAL ORIGINS FOR THE ROTATION
bpy.ops.transform.rotate(value=(3.1415,),axis=(0,1,0), constraint_axis=(True,True,True), constraint_orientation='GLOBAL')
bpy.ops.object.add()                                              # ?
bpy.data.objects['Empty'].select=True                             # ?
bpy.data.objects['Empty'].name="Aux_Empty"                        # ?
bpy.context.active_object.location =(0.0, 0.0, 0.0)               # ?
bpy.data.objects['Aux_Empty'].select=False                        # ?
#bpy.context.scene.frame_set(currentframe)                                      # ?
bpy.data.objects['Aux_Empty'].select=True                                       # ?
bpy.context.scene.objects.active = bpy.data.objects['Aux_Empty']                # ?
obj = bpy.context.object                                                        # ?
obj.location[2] = 0.0                                                           # ?
obj.keyframe_insert(data_path='location')                                       # ?
bpy.data.objects['Aux_Empty'].select=False                                      # deselect before deleting stuff
#-- Import the bathymetry
bpy.ops.import_scene.x3d(filepath= path_to_bathy+filename_of_bathy+'.x3d', filter_glob="*.x3d;*.wrl", axis_forward='Z', axis_up='Y')
bpy.data.objects['ShapeIndexedFaceSet'].name="imported_bathymetry"
bpy.data.objects['imported_bathymetry'].select=True
bpy.context.scene.objects.active = bpy.data.objects['imported_bathymetry']
bpy.context.active_object.material_slots[0].material.use_vertex_color_paint=True
bpy.data.objects['imported_bathymetry'].select=False
bpy.ops.object.delete()
bpy.context.scene.cursor_location = (0.0, 0.0, 0.0)              #set the cursor to the center
bpy.ops.object.origin_set(type = 'ORIGIN_CURSOR')                #set the origin to the cursor
bpy.ops.object.origin_set()                                      #set the geometry to the origin
bpy.ops.transform.resize(value=(scalefactor,scalefactor,scalefactor))                    #resize the bathymetry
bpy.ops.transform.translate(value=(0, -.7, 0), constraint_axis=(False, False, False), constraint_orientation='GLOBAL')   #choose better value for the translation !!!
bpy.ops.object.shade_smooth()                                    #smooth the bathymetry
#-- Treatment of the files for each timestep
for currentframe in range(startframe_ofx3d,(endframe_ofx3d+1)):
    #---------------------------Import the x3d file---------------
    bpy.ops.import_scene.x3d(filepath= path_tox3d+filename_ofx3d+str(currentframe)+'.x3d', filter_glob="*.x3d;*.wrl", axis_forward='Z', axis_up='Y')
    #--rename the geometry to "imported geometry"
    bpy.data.objects['ShapeIndexedFaceSet'].name="imported_geometry"
    bpy.data.objects['imported_geometry'].select=True
    bpy.context.scene.objects.active = bpy.data.objects['imported_geometry']
    bpy.data.objects['imported_geometry'].select=False
    #-- delete all of the artefacts added when importing the x3d file
    #--Rescpale and reorientate the imported geometry
    bpy.ops.transform.resize(value=(scalefactor,scalefactor,scalefactor))                    #resize the geometry
    #-- set the rendering options
    bpy.data.scenes['Scene'].render.resolution_percentage=100
    bpy.data.objects['imported_geometry'].select = False
    bpy.data.objects['Camera'].select = True
    bpy.ops.render.render(write_still=True)
    bpy.data.images['Render Result'].file_format='PNG'
    bpy.data.images['Render Result'].save_render(filepath=path_toimage+filename_ofimage+str(currentframe)+'.png')
thanks in advance.
CoDEmanX
Post by CoDEmanX » Fri Jan 11, 2013 1:34 am
selecting a camera object won't help, you need to set the scene's camera:
bpy.context.scene.camera = bpy.data.objects['Camera']
werty_TSS
Post by werty_TSS » Fri Jan 11, 2013 2:01 am
CoDEmanX wrote:selecting a camera object won't help, you need to set the scene's camera:
aaaah yeah I see! it works now, thanks a lot!
