Creating objects optimally
BYAHHHH
Post by BYAHHHH »
What would be the fastest way to allocate 835902500 vertices to 33144 different objects (a single object may have multiple meshes, or multiple splines)
Any advice would be helpful...
Code: Select all
This script reads shapefiles into blender.
import csv
import os
import sys
import shapefile
def partitionParts(allPoints,partList):
	components=[]
	for i in range(len(partList)):
		if( i != (len(partList)-1)): components.append(range(partList[i],partList[i+1]))
		if( i == (len(partList)-1)): components.append(range(partList[i],len(allPoints)))
	subsets=[]
	for n in range(len(partList)):
		subsets.append([allPoints[i] for i in components[n]])
	return(subsets)
def vectorize(pointList2D):
	for i in range(len(pointList2D)):
		pointList2D[i]=list(pointList2D[i][0:2])
		pointList2D[i].append(0.0)
		pointList2D[i]=Vector(pointList2D[i]) #pointList2D is now actually a list of 3D vectors
def plot_ShapeRecord_object(shapeRecord_object):
	fails={"index":[],"name":[]}
	xx=shapeRecord_object
	try:
		name=str(xx.record[6])
		cu=bpy.data.curves.new(name,'CURVE')
		ob=bpy.data.objects.new(name,cu)
		bpy.context.scene.objects.link(ob)
		if len(xx.shape.parts)>1:
			y=partitionParts(xx.shape.points,xx.shape.parts)
			for i in y:
				vectorize(i)
				spline=cu.splines.new('BEZIER')
				spline.use_cyclic_u=True
				spline.resolution_u=1
				cu.resolution_u=1
				cu.render_resolution_u=1
				cu.dimensions='2D'
				spline.bezier_points.add(len(i)-2)
				for k in range(len(i)-1):
					spline.bezier_points[k].co=i[k]
		if len(xx.shape.parts)==1:
			y=xx.shape.points
			vectorize(y)
			cu.resolution_u=1
			cu.dimensions='2D'
			spline.bezier_points.add(len(y)-2)
			for k in range(len(y)-1):
				spline.bezier_points[k].co=y[k]
		bpy.context.scene.objects.active=bpy.data.objects[name]
		bpy.ops.object.mode_set(mode='OBJECT')
		bpy.ops.object.select_all(action='DESELECT')
		bpy.data.objects[name].select=True
		bpy.ops.object.mode_set(mode='EDIT')
		bpy.ops.curve.select_all(action='SELECT')
		bpy.ops.curve.handle_type_set(type='VECTOR')
		print(name + " has been initialized.")
	except:
		print(name + " FAILED TO INITIALIZE.")
		fails["index"].append(sf.index(xx))
		fails["name"].append(name)
# os.chdir('D:/Documents and Settings/******/Desktop/[blender work]/shapefile')
# sf=shapefile.Reader('tl_2012_17_cousub.shp')
# sf=sf.shapeRecords()
# def drawShapefile(location):
Call the pairs elements:
(spline_a, spline_b)
import itertools
def seperate_overlaps(list_of_curve_objects,error=.00005):
	for an_object in list_of_curve_objects:
		try:
			for pair in itertools.combinations(an_object.data.splines[:],2):
				for index_a, element_a in enumerate(pair[0].bezier_points[:]):
					for index_b, element_b in enumerate(pair[1].bezier_points[:]):
						if element_a.co == element_b.co:
							print(index_a,index_b)
							direction_a=(pair[0].bezier_points[index_a-1].co-element_a.co) + (pair[0].bezier_points[index_a+1].co-element_a.co)
							direction_b=(pair[1].bezier_points[index_b-1].co-element_b.co) + (pair[1].bezier_points[index_b+1].co-element_b.co)
							if direction_a==direction_b:
								element_a.co+=direction_a.normalized()*3
							elif direction_a != direction_b:
								theta=direction_a.angle(direction_b)
								s=sqrt((error**2)/(2-2*cos(theta)))
								element_a.co+=direction_a.normalized()*s
								element_b.co+=direction_b.normalized()*s
		except:
			print(an_object)
			print(pair)
			print('\t',index_a,element_a)
			print('\t',index_b,element_b)
location='E:/shapefiles/tl_2012_us_zcta510/tl_2012_us_zcta510.shp'
# os.chdir(location)
sf=shapefile.Reader(location)
for ii in range(sf.numRecords):
	xx=sf.shapeRecord(ii)
	try:
		name=str(xx.record[1]) #zipcodes are at 1, names are at 6
			for i in y:
				vectorize(i)
				cu.resolution_u=1
				cu.dimensions='2D'
			y=xx.shape.points
			vectorize(y)
			cu.resolution_u=1
			cu.dimensions='2D'
	except:
