Calling an executable
michael75
Post by michael75 »
Iv tried to find info on this but no joy. Basically i have a simple c# exe that opens loads an image, resizes it and save it before closing, very simple.
Iv tried the popen and subprocess.call with and without shell and i get nothing on the console as an error but the exe did not execute.
So i made a .bat file calling the exe, which i tested and it works but when i call that from script i get a windows "cannot find file...." message.
So guessing maybe python doesnt like my paths i put the whole lot on the root but still it wont run.
Iv tested other exe's on the root and in folders and they run ok.
My exe is just a form with a picturebox and about 3 line of code on the form_load.
stiv
Post by stiv »
At the risk of being Captain Obvious, likely you are doing something wrong. Hard to say what exactly without some code.
michael75
Post by michael75 »
haha yes i believe so, and my god i hope your right as my brain died 10 hours ago :(
subprocess.Popen(["path to the file.exe"])
subprocess.call(["Path to file.exe"], shell = True)
iv tried this, havent the exact code as it was just a test on a blank script but as i say it worked fine on other exes in the folder or elsewhere seems like python doesnt like a simple compile from c#?
Also im baffled why the batch file works from explorer but not script.
Im using blender 6.7 and alot on the web is for older versions. But i would presume i have to pass something other than "call" to my file or my file needs some kind of property or value it doesnt. If somebody had c# maybe they could try.
stiv
Post by stiv »
My guess: your path has backslashes ( the \ char) in it. A number of backslash/single-character combinations are ASCII escape sequences for things like a tab (\t) or a new line (\n). These will mess up your file path.
Windows does (or did!) recognize the forward slash (/) as a valid separator. If you have something like "C:\this\will\not\work.exe", try changing it to "C:/this/will/not/work.exe".
Or build paths with the os.path module.
michael75
Post by michael75 »
Yeah i copped the \\ trick, but it seemed that my exe was at fault. I recreated it giving it complete properties and then published it and i could then call it.
My next problem is sending a command line to the exe, it seems that
os.popen(["c:\\Myexe.exe mycommand"])
is seen as literal file path as is get a file not found issue.
Is it possible to send a command line string in bpy? if not i can work around but it would be the best option for me.
michael75
Command line Arguments
Post by michael75 »
Ok first thanks stiv for repling to my noob questions.
Ok so iv found out that popen is structured as:
os.popen(["c:\\test\\app.exe","/s"])
so that you can pass the command "/s" to app.exe just incase anyone else has this issue.
stiv
Post by stiv »
Glad it is working for you! And thanks for reporting back. I'm sure that will help someone else.
