Selecting Object
Akos
Selecting Object
Post by Akos »
i need to change the corrent selected object in the phyton code. Basecally i want to get the same result as clicking with the right click of the mouse of an object (selecting it). By this the
Code: Select all
bpy.context.object
will be changed. I cant change directly the bpy.context.object because it is a readonly one.
Help me please :(
orimouse
Post by orimouse »
It's quite difficult to give you a precise answer without more information, but you can simply define a variable such as :
Code: Select all
obj = bpy.context.object
and put it in each function or class where your current active object may change.
CoDEmanX
Post by CoDEmanX »
This reproduces the right-click behavior
Code: Select all
# assuming, "ob" is an object reference
bpy.ops.object.select_all(action='DESELECT')
ob.select = True
bpy.context.scene.objects.active = ob
Akos
Post by Akos »
Thank you a lot guys, if worked out the bpy.context.scene.objects.active
Akos
