Problem with armature bone rotation via Python
rbstarbuck
Post by rbstarbuck »
I'm very new to Blender, so please forgive my incompetence. I need to control an armature using Python so that I can animate a biped model using data from a text file. I've been using this tutorial and some other sources to try and do so, but I can never see any results in the rendered game window.
The test code I have thus far is:
Code: Select all
import GameLogic
arm = bge.logic.getCurrentScene().objects.get('Armature')
arm.channels['Upperleg.L'].rotation_mode = 1
print(arm.channels['Upperleg.L'].rotation_euler)
arm.channels['Upperleg.L'].joint_rotation = [.5, .5, .2]
arm.update()
In the console, the values for BL_ArmatureChannel.rotation_euler are changing...
Code: Select all
<Vector <0.0000, 0.0000, 0.0000>>
<Vector <0.5849, 0.4207, 0.3372>>
...but nothing is happening with the model linked to the armature (not visually at least).
On my armature, I have an "Always" sensor attached to a "Python" controller to execute the script. There are no IK constraints on the armature and no other sensors/controllers/actuators. I've added test code to rotate the entire armature--.applyRotation()--which works, but I can't seem to rotate individual joints.
Any help on this matter would be greatly appreciated, my research sponsor is breathing down my neck to get this project done and I can't seem to get this very simple (but necessary) part of it working.
