rotation command?
Jedijds
rotation command?
Post by Jedijds »
What command do I use to find the angle of rotation and set the rotation of and object?
۞◄█°‖‖‖‖‖█ʭʭ╬(░▒▓▓▒▒▒▒▒▒▒▒▒)
CoDEmanX
Post by CoDEmanX »
Depends... do you mean the object rotation or the orientation of a mesh's data?
Object rotation can be read, from matrix_world.to_3x3() or the appropriate rotation_* attribute (depends on mode)
You can assign to these attributes, or use the transform.rotate operator. Angle.is.given in radians.
Jedijds
Post by Jedijds »
this command finds its position, bge.logic.getCurrentScene().objects['Cube'].worldPosition[0] , but what about a command that finds its rotation? does that help any?
CoDEmanX
Post by CoDEmanX »
oh is it about the game engine?
Jedijds
Post by Jedijds »
yes, I should have mentioned that first, is there some other place I need to ask for the bge?
CoDEmanX
Post by CoDEmanX »
well, either post BGE script questions here with a note that it's about BGE or use the Interactive 3D section: http://www.blender.org/forum/viewforum.php?f=13
see this page for rotation in bge:
http://www.blender.org/documentation/bl ... rientation
Jedijds
Post by Jedijds »
yes I looked there, is the local orientation the command im looking for? if I put 1 for x and then run the command worldPosition[0] I get 1 now what about rotation if I put 1 degree for x axis how do I find that through text editor? if the object gets applied rotation I want to know what angle its now facing.
CoDEmanX
Post by CoDEmanX »
the BGE module is only available while game engine is running, you can't test BGE-specific code "outside"
localOrientation or worldOrientation are the relevant ones, yes. They return a 3x3 rotation matrix. Not sure about the axis in bge, but -Y of the matrix might be the forward vector.
