Error in the mathutils RotationPart() function
the rotationPart() function of the class in matrix in the mathutils module gives a inexact result. the rotation matrix given is multiplied by the size of the object.
print the rotation matrix of an object with size 1, then with size 2 and finally with differents sizes along each axis, they should not be different.
i don't try other function.
I think this is not really a bug:
The part that is returned by the rotationPart() method holds the values the for the overall transformation, which is rotation _and_ scaling.
The resulting rotation ist still correct (i.e. Euler rotation).
Take the differently scaled objects which xand mentioned.
Their rotation matrices are different, because the rotation matrix which is returned by objmatrix.rotationPart() does not only hold information about the object's rotation, but also about the object's scaling (the this rotationpart is obivously taken directly from the orginal 4x4 object matrix).
This may not be a problem when you derive euler angles from such a (possibly scaled) rotation matrix, because the matrix rotation is still correct.
But this should be taken into account when you start doing things like:
I think this is rather a feature and not a bug
Code: Select all
from Blender import *
Obj1=Object.Get("Cube")
Obj2=Object.Get("Cube.001")
m1 = Obj1.getMatrix() # copy rotation from Obj1
m1rot = m1.rotationPart() # by getting the rotationPart()
m2 = Obj2.getMatrix() # Get Obj2 Location
m2trans = m2.translationPart()
# resize matrices for multiplication
m1rot.resize4x4()
m2trans=Mathutils.TranslationMatrix(m2trans)
m2new= m1rot * m2trans # Obj2 will receive rotation AND scaling
Obj2.setMatrix(m2new) # from Obj1.
Window.RedrawAll()
that's why i called it an error and not a bug.
you can create a pure rotation matrix or a pure scale matrix from angle and value but you can extract them.
i need to apply rotation from an object to another regadless their size.
so i must extract each part of the matrix to divided it by the corresponding size.
it would be better is the rotationpart be the pure rotation matrix.
Strangly I ran the above example with 2 differently scaled cubes and found no difference. Maybe a .blend that illustrates the problem?
The rotationPart() internal matrix function is to return the tranformation of a n-dimensional matrix. It is probably named poorly. To get the rotational information from the transformation you could get it's quaternion or euler value then construct a rotation matrix based on this information.
that's what i do now but i think the result of this piece of code should be the same. but anyway, the second determination works even it seems ugly.
Code: Select all
from Blender.Mathutils import *
print 'start'
ob=Object.Get('Empty')
m=ob.mat
mrot=m.rotationPart()
print mrot
mrot2=m.toEuler().toMatrix()
print mrot2
There isn't really a problem to demonstrate: The code just shows how the rotationmatrix applies rotation and scaling to an object.ascotan wrote:Strangly I ran the above example with 2 differently scaled cubes and found no difference. Maybe a .blend that illustrates the problem?
That's what we're talking about:The rotationPart() internal matrix function is to return the tranformation of a n-dimensional matrix. It is probably named poorly.
If I understand xand correctly, rotationPart() should return a 'normalized' rotation matrix, while I think it's ok the way it is. Otherwise you would need another way to extract the 3x3 transformation from the 4x4 object matrix in the cases where you need the scaling transform.
Hmm, why not use the quat right from the start:To get the rotational information from the transformation you could get it's quaternion or euler value then construct a rotation matrix based on this information.
Code: Select all
MyObject.toQuat().toMatrix()
Code: Select all
MyObject.rotationPart()
