Alright, I know this is whack, but can you...
scooterl
Post by scooterl »
Is it possible to render a single pixel at a certain x,y,z coordinate?
Not a mesh object, but a purely added pixel, at a certain depth, that can be situated in front of/behind mesh objects depending on camera location.
I wonder this because I'm planning out a script to generate a variable-depth mist (instead of the current "Wall O' Dust" mist, which is easily ten years behind the times).
I need to be able to write depth-conditional RGBA values directly to the rendered image.
Is there a way to render a single pixel at a certain x,y,z coordinate?
matt_e
Post by matt_e »
I think you should be able to do this with a video sequence plugin? (has access to RGB pixels and Z-buffer).
Here's a tutorial on writing one:
http://www.blender.org/modules/document ... 11071.html
ideasman
Post by ideasman »
you can set the render boarder to a floating pt value- but this isnt 1 px.
scooterl
Post by scooterl »
Thanks to both of you.
I was hoping to do it as a script in Python, but the plugin approach may be the way to go. Sadly, my skills in writing .c are pretty poor :(
I only used the 'pixel' idea as a metaphor, and perhaps an inaccurate one at that. The problem I'm having is trying to figure out how to write an RGBA value to a particular (x,y,z) coord...
I'll just keep playing at it a bit.
Thanks again.
ideasman
Post by ideasman »
your probably better to render the image and then use a python image processing lib SDL/Pygame are good.
