Calculator script?
calli
Calculator script?
Post by calli »
often I need some quick calculations while blending.
Is there already a python script providing a calculator?
Too bad I have no time to implement one.
Regards,
Carsten
theeth
Post by theeth »
You could just do it interactly (sort of).
form math import *
at the top of the script and then just type in the equations like this
print cos(0.5) + 0.2 + log(10)
(not sure if log exists, but you get the idea).
Then run the script and look in the console.
Primitive, but it works.
- John Lennon
calli
Post by calli »
@theeth: Sure but thats much more complicated than starting a calculator (xcalc or Windows whatever) and switching programms ;-)
Regards,
Carsten
halibut
Post by halibut »
It would be really nice if you could enter such calculations straight in to number buttons and then have them evaluated when you press enter. I tried to look in to the code to do this myself but I couldn't work it out :?
ilac
Post by ilac »
halibut wrote:It would be really nice if you could enter such calculations straight in to number buttons and then have them evaluated when you press enter. I tried to look in to the code to do this myself but I couldn't work it out :?
Like in Macromedia freehand! that is a really practical and useful means of updating info in num buttons!
halibut
Post by halibut »
bah! they stole my idea :D
fligh
Post by fligh »
http://come.to/project5/mathter
Stick the script in a text window and it'll run in the console. Or you can run it as a standalone.
oyster
Post by oyster »
jms
Post by jms »
import Blender
from Blender.Draw import *
from Blender.BGL import *
from math import *
datastring=Create('0+0')
def gui():
  global datastring
  glClearColor(0.5,0.5,0.5, 0.0)
  glClear(GL_COLOR_BUFFER_BIT)
  Button("Exit", 1, 310, 10, 80, 19)
  glRasterPos2i(10, 100)
  Text("Calculator")
  datastring= String("Enter : ", 2, 10, 70, 380, 19, datastring.val, 70)
  glRasterPos2i(20, 50)
  Text("Result : "+str(eval(datastring.val)))
def event(evt, val):
  if (evt== QKEY and not val): Exit()
  Blender.Redraw()
def bevent(evt):
  if   (evt ==  1): Exit()
  Blender.Redraw()
Register(gui,event,bevent)
Zoo-3D.Blender, Ze French-Speaking Community SKB My french book about Blender.
ilac
Post by ilac »
jms wrote:
import Blender
from math import *
def gui():
  global datastring
  Text("Calculator")
  Blender.Redraw()
def bevent(evt):
  Blender.Redraw()
Nice! :shock:
Thanks! :D
BILL
Post by BILL »
jms wrote:
import Blender
from math import *
def gui():
  global datastring
  Text("Calculator")
  Blender.Redraw()
def bevent(evt):
  Blender.Redraw()
good
jms
Post by jms »
Nicer : with exception error handle :
http://jmsoler.free.fr/didacticiel/blen ... ulator.htm
