Python script ERROR : check Console ????? Help me
viet
Post by viet » Thu Mar 17, 2005 7:41 pm
i try to run a python script and i got that error . I use Python 2.4 and Blender 2.36 . Help me please . Show me how to run it ?
ascotan
Post by ascotan » Fri Mar 18, 2005 5:04 pm
If your using windows the error will appear in the other DOS window, Unix and it' will appear in the terminal output (only if you run blender as ./blender from the terminal).
I would check over at elysiun.com as there are many script writers there.
viet
Post by viet » Sat Mar 19, 2005 12:32 pm
i use WinXP , what can i do ?
Sutabi
Post by Sutabi » Sun Mar 20, 2005 4:47 am
its the using of python 2.4, Blender 2.36 uses python 2.3.
I got a question... will blender 2.37 support python 2.4?
Post by stiv » Sun Mar 20, 2005 4:09 pm
Sutabi wrote:I got a question... will blender 2.37 support python 2.4?
Probably not.
You can compile it yourself against python 2.4 though and it *should* work. Let us know if you do.
theeth
Post by theeth » Sun Mar 20, 2005 7:42 pm
Probably not.
I already do for some months and I haven't had much problems. The only ones were because I'm running 2.4 in parallel with 2.3 and my python path has mixed version folders.
- John Lennon
Sutabi
Post by Sutabi » Tue Mar 22, 2005 5:58 am
well since I am a windows/linux user Ill try in linux. I hate windows when it comes to c code (mainly due the fact if you dont have msvc++ 7, your gonna have a lot of troble compling it)
*huges linux and gcc*
LetterRip
Post by LetterRip » Sat Mar 26, 2005 5:01 am
compiling blender on windows with cygwin gcc is acutally pretty straight forward,
LetterRip
