getting current .blend file
Sutabi
Post by Sutabi » Fri May 20, 2005 2:26 am
I know in the lib module you can get the filename of the .blend you are append, but what about the current .blend you are using.
z3r0_d
Post by z3r0_d » Fri May 20, 2005 6:26 am
import Blender
print Blender.Get('filename')
note that if no file has been loaded this is the last file loaded on your previous blender session... as in it is the file you get when you hit control+o
