Get a camera's view and send it through socket communication
AgentCain
Post by AgentCain »
I am working on a server-client system which will estimate a person's pose
I would like to have blender function as a server, using python scripting and socket communication. It will manage a human articulated model, take as input the joints position (or movement in general) and respond with the models view both in depth and visual image. This will afterwards be compared to the actual scenery, so the pose can be estimated.
The reason I chose blender is because i dont want to have to deal with bones system and meshes rendering. It could be done in openGL but its such a pain you know where.
So is it possible to get a camera's view and store it somehow in a python variable? The only thing I can find is render the scene and store it in a file using scripting, but that would be extremly inefficient and slow for my purposes. I dont really have a need for quality rendering. In fact I would prefer low quality rendering in order to achieve better response times.
Im using windows 7 64bit and blender 2.64
AgentCain
Post by AgentCain »
I just had an idea
Since you can load the result of opengl to opencv using glReadPixels(), I probably could do the same through the Blender's opengl wrapper
Will try and report. If anyone else has another solution, please dont be shy :P
Post by stiv »
The glReadPixels() function is rather slow on consumer graphics cards.
Seems easier to render the image at your chosen resolution and write it to a socket or named pipe.
AgentCain
Post by AgentCain »
Could you propose any method?
All I could find is
bpy.data.scenes[].camera = obj
bpy.data.scenes[].render.file_format = 'JPEG'
bpy.data.scenes[].render.filepath = '//camera_' + str(c)
which is useful for saving a rendered scene as an image by calling
 bpy.ops.render.render( write_still=True )
The blender.python documentation is rather difficult to navigate :oops: [/code]
CoDEmanX
Post by CoDEmanX »
how about something like
bpy.ops.render.opengl()
bpy.data.images['Render Result'].save_render("D:\\viewport_render.png")
AgentCain
Post by AgentCain »
CoDEmanX wrote:how about something like
The thing is I want to avoid writing to a file because it will be extremely slow writing lets say 50 .png and then open them.
Of course I could use a Ramdisk partition to gain some speed, but Id like to avoid it and pass the rendered result to another process through socket communication.
It would be ideal to render it in a variable and pass it through localhost UDP/TCP
CoDEmanX
Post by CoDEmanX »
you could try to expose the pixels (Image.pixels) of an image for render results, this is current available to python for images, movies and uv test textures (not generated textures).
AgentCain
Post by AgentCain »
CoDEmanX wrote:you could try to expose the pixels (Image.pixels) of an image for render results, this is current available to python for images, movies and uv test textures (not generated textures).
So image.pixels gives a matrix-like access to a rendered scene's pixel data? I guess I could pass this through and use blender nodes to make my depth map render, so i can trasmit that aswell
Post by stiv »
Blender has (or did!) a frameserver, capable of sending rendered output via http protocol. Basically, you send a request for particular frame and get back the image in PPM format.
http://wiki.blender.org/index.php/Doc:2 ... rameserver
AgentCain
Post by AgentCain »
I found this on blenderartists.org:
http://blenderartists.org/forum/showthr ... it-as-file
Alternatively you could use the z-buffer of the 3d-view. Here's some code to do that:
import Blender
from Blender import *
from Blender.BGL import *
windows = Window.GetScreenInfo()
for w in windows:
    if w['type'] == Window.Types.VIEW3D:
        xmin, ymin, xmax, ymax = w['vertices']
        width = xmax-xmin
        height = ymax-ymin
zbuf = Buffer(GL_FLOAT, [width*height])
glReadPixels(xmin, ymin, width, height, GL_DEPTH_COMPONENT, GL_FLOAT, zbuf)
strbuf = []
for i in range(height):
    strbuf.append(str(zbuf[i*width:i*width+width]))
strbuf.reverse()
file = open("C:/test.txt", "w")
for i in strbuf:
    file.write(i[1:-1]+'\n')
file.close()
This looks to me as a great way to get a fast and simple render, since it actually uses the 3dview's output (no shadows, lighting, ambient occlusions, smoothing etc). But Im really confused with the blenders documentation http://www.blender.org/documentation/bl ... pi_2_64_9/# and the way its organized. Did blender change so much over its versions?
Post by stiv »
Big Time. Major differences between the 2.4x series and 2.6x - both internally and in the BPy API. Oh, and the user interface, too!
Note the Z-buffer is only the depth information, a single float for each pixel, like a height map or gray scale image.
AgentCain
Post by AgentCain »
I guess i should try an older version then :P
stiv wrote: Note the Z-buffer is only the depth information, a single float for each pixel, like a height map or gray scale image.
Actually, depth information is the most important thing I need, I dont need visual rendering so much (It could help, but if its missing its no deal braker)
CoDEmanX
Post by CoDEmanX »
AgentCain wrote:
CoDEmanX wrote:So image.pixels gives a matrix-like access to a rendered scene's pixel data? I guess I could pass this through and use blender nodes to make my depth map render, so i can trasmit that aswell
it's just image data, RGBA
[0] = red of first pixel
[1] = green
[2] = blue
[3] = alpha
[4] = red of second pixel
etc.
AgentCain
Post by AgentCain »
Ok
So for my first try, I used glReadPixels on the GL_DEPTH_COMPONENT
but, it returns a matrix of 1.0 :(
Whats the problem?
AgentCain
Post by AgentCain »
Solved the problem
Apparently, one script execution doesnt work. On the second run you have depth results
Now its a matter of remapping the values from [min,1] to [0,1] or [0,255]
